delayed drive
Old Feb 4, 2008 | 09:32 AM
wizzard351's Avatar
wizzard351
delayed drive
has anyone ever had it when ya put it in drive it just sits there for about 15 sec before itll drop into gear? my 96 F250 HD is doin that now the fluid levels is good and fresh oil and filter. ive talked to a few folks about this and they tell me a HD truck is spose to "soft shift into drive" personaly ive never herd of this. mabe its just ben to cold and nothing works good when its ben as cold as it has ben here
Old Feb 4, 2008 | 09:35 AM
dave2's Avatar
dave2
When did it start doing this? Could it be that the new fluid woke up an old problem that an addative had covered up?
Old Feb 4, 2008 | 09:44 AM
wizzard351's Avatar
wizzard351
well its be doing it for some time already even before the fluid change. seems to get better when its warmed up good
Old Feb 4, 2008 | 09:52 AM
dave2's Avatar
dave2
I haven't dealt with automatic transmissions, but is there such thing as flushing the system? Sounds like things are not flowing as good as they should until things are warm and thinner. Transmission shops used to offer fluid/filter changes with band adjustment. Maybe google your problem with adjustment in there somewhere and see what comes up. Or just wait on some of the smarter people to wake up.
Good luck,
Dave
Old Feb 4, 2008 | 10:06 AM
ned37's Avatar
ned37
sounds like your torque converter bleeds down after sitting for awhile. no problem as long as you're patient.
Old Feb 4, 2008 | 10:30 AM
wizzard351's Avatar
wizzard351
ok that makes sence cuzz its fine after it gets moving and even at a stop sign itll stay in gear and what not. i wonder what would cause bleed down never herd of that one. if its an expensive fix ill just run it till it dont move then rebiuld
Old Feb 4, 2008 | 10:55 AM
ned37's Avatar
ned37
i was told that some rebuilders do it on purpose for some unknown (to me) reason. my 92 f250 diesel does it. i don't think you would have any problems from it. its just a nuisance when you're in a hurry. mine is fine after it idles for about 15 seconds. just enough time to put the faceplate on the radio and seatbelt/sunglasses.
Old Feb 4, 2008 | 12:32 PM
Animalistic's Avatar
Animalistic
Mine does this too but it doesn't take that long. When I fire up cold in the morning, I let the high idle come down, put the radio faceplate in and find a station that has something I like. I put it in reverse to back out of the driveway and it shifts fine. When I stop on the street and put it into drive, it can take as long as 5 to 8 seconds to hit the gear. Then it works fine. I had the trany checked at my local shop and he gave it a clean bill of health and said this is normal. After seeing this post, I guess he is right.
Old Feb 4, 2008 | 02:30 PM
quicklook2's Avatar
quicklook2
when you say 'fresh oil and filter" do you mean you dropped the pan and replaced filter and put pan back on and filled the fluid?
if you did only this and did not drain the convertor at the same time than that is your problem.
Old Feb 4, 2008 | 02:44 PM
wizzard351's Avatar
wizzard351
it was hooked to a flush machine both lines where disconected and run to this machine as the old fluid is pumped into it new fluid is pumped back into the trans, some where in this process the filter was changed i dont no all the details how this works but for $69.99 i wasnt complaining
Old Feb 4, 2008 | 03:21 PM
quicklook2's Avatar
quicklook2
i would try draining it again, manually.
that sounds too cheap for good fluid, a good filter/gasket and the time to do it.
