Sponsored by: Real Truck
Stock U-joint longevity
Old Feb 4, 2008 | 09:24 AM
cyclenut80's Avatar
cyclenut80
I've got close to 130k on my 01 F-250 and as far as I know all the u joints are stock except for the front axle shafts...did them when I did ball joints. Anyone know if I should replace these? I know the ones on the front were pretty close to being totally siezed. Everything seems to be fine with them but I keep thinking that maybe I should just change them out anyway after seeing what condition the fronts were in. Maybe I can squeeze out a few extra mpg?
Old Feb 4, 2008 | 10:28 AM
cgl's Avatar
cgl
I had to replace mine at 90k on my '02. BUT not because any of the three u-joints in the back went bad... It was the needle bearings in the double-carden joint at the transfer case yoke that went south. Causing one hell of a vibration!
Old Feb 4, 2008 | 10:44 AM
redford's Avatar
redford
FTE Leadership Emeritus
Replace them if they are "totally siezed." There are a lot of factors that affect how many miles you get out of a set of U-joints, so just replace them when they start causing problems or making noise.
"totally siezed" falls under causing a problem.
Old Feb 4, 2008 | 02:20 PM
cyclenut80's Avatar
cyclenut80
LOL well I suppose that should be obvious redford...I'm just saying that before I did the u-joints on the axle I didn't have any noise or vibration problems. Seeing how they are all the same age and the driveshaft u-joints get a hell of a lot more wear I might be smart to do it.
Old Feb 4, 2008 | 03:19 PM
rbaker6336's Avatar
rbaker6336
when they give a problem replace the,until the enjoy them,there really ain't a deadline
Old Feb 4, 2008 | 04:21 PM
boxcar1974's Avatar
boxcar1974
My F250 has original U-joints at 90K miles and my F350 DRW dump bodies had them go out at 6K miles. It all depends.
Old Feb 4, 2008 | 07:07 PM
F350-6's Avatar
F350-6
I've still got my stockers. As everyone else said. Replace them when they give you a reason to.
Old Feb 4, 2008 | 07:14 PM
Kory Zimmerman's Avatar
Kory Zimmerman
Got 285,000 and still going strong, just replaced the rears two weeks ago. It's a 99 F-350 CC SRW Long Box with a 4" lift.
Old Feb 4, 2008 | 07:26 PM
jrtraderny's Avatar
jrtraderny
Traded my '99 with 166,000 on it with all original u-joints ,except for the axle joints still in it.
jr
Old Feb 4, 2008 | 11:05 PM
rusty350250's Avatar
rusty350250
my rear double carbon failed at around 75000, i chaged the front shaft ones around 80000(they were still good just a precautionary) the front axel joint were changed when the shafts were change around 60000 both were good but sinse i was changing my stubs might as well change the joints. u joint life depends on many factors load on them(tow heavy load,heay payload, lots of offroad, alot of water and mud running. my rear went mostly due to offroading and loads.
Old Feb 5, 2008 | 04:51 PM
actech's Avatar
actech
244,000 on mine, replaced the carrier bearing about 1000 miles ago but kept the u-joints, still good why replace?
Old Feb 5, 2008 | 06:59 PM
G BOBKA's Avatar
G BOBKA
U-joints are fine. Replace both front hubs at about 90,000 . And I just found out tonight that I can service . I have 160,000 miles on my F350 7.3 diesel that I bought in 2000. I carry a 16 foot trailer.. , and also I have a 25 foot boat , which is very heavy. And I have not heard a squeak out of the joints.
Volvo92906
Jun 2, 2011 02:09 PM
ac700wildcat
Apr 15, 2010 09:11 PM
SHOpar
Jun 21, 2009 10:32 AM
Hamberger
May 24, 2007 10:03 AM
clings89
1983 - 2012 Ranger & B-Series
Jan 28, 2007 12:57 PM
