U-Joints you can grease
Old May 22, 2007 | 01:21 PM
Hamberger's Avatar
Hamberger
Has anybody come across U-Joints for the Front Axles that you can grease properly.
I just limped home from a trip to the cabin with a bad left front U-Joint on my 91 F-350. I had serviced the front axle less than 18 month ago and should have put in new U-Joints instead of just blasting them with WD-40 to get them moving freely at the time.
My question is, does anybody know where to get joints that you can actually grease after you come out of the mud so the darn things don't rust up before the next time you want to use them.
The U-Joints are a real problem on the 91' F350 which has automatic hubs. With the bad U-joint the left hub would not unlock and I ended up driving 400 miles with a cluncking U-Joint, luckily the thing stayed together.
All I could find from Ford, Napa, Lordco, etcc... were the non-greaseable kind of joints. Since you can't get a grease nipple on the cross, what you would need is grease nipples on the tips of each cross. They would definetely have to be low profile to fit. Besides grease nipples on the cross don't guarantee that all four bearings get grease.
Any help finding greaseable joints would be much appreciated.
Seb.....
Old May 22, 2007 | 03:23 PM
PLC7.3's Avatar
PLC7.3
Check out the extra heavy duty/performance universals they usually have the cross type grease system.......
Old May 22, 2007 | 06:40 PM
Winger235's Avatar
Winger235
I replaced mine from Carquest last year they had fittings.
Old May 22, 2007 | 08:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Spicers are greaseable.
I buy them at NAPA here.
The zerk is on the cross, I have a 92 D60 front axle.
Advance Auto and Autozone also have greasable U joints for the Dana 60.
Old May 22, 2007 | 10:21 PM
dwkremer's Avatar
dwkremer
I replaced mine last year from AutoZone and they had grease fittings.
Old May 23, 2007 | 08:09 PM
KJLYPW's Avatar
KJLYPW
In Canada, I got mine from the local Kal tire dealership, also the store here is an Industrial supply store.
Old May 24, 2007 | 10:03 AM
Hamberger's Avatar
Hamberger
Thanks everybody,
Got the front end back together last night. I put in Precision U-Joints. (Part Number 374) They have atleast a grease nipple on the cross which is better than nothing. I am turning into a regular Pro at this. I guess if the engineering thing does not work out I could always become a front end man.
Ideally it would be nice if you could grease each bearing individually as that is the only way to ensure each bearing actully gets grease and any water gets pushed out.
Well it's been close to 10 years since I did the U-Joints on my 93 F250 and it never did get grease nipples, maybe it was just the crappy OEM U-Joints that caused all my problems in the first place.
Last note, prices sure have gone up for parts since I bought them last. I would say atleast 30% to 40%.
Seb..
MikeFlorida
May 13, 2007 06:52 PM
Keepin It Real
Apr 9, 2007 06:21 PM
Gearheadjo
Nov 16, 2006 06:12 PM
superrangerman2002
1997 - 2003 F150
Aug 19, 2004 11:56 PM
