Sponsored by: Real Truck
How accurate is it?
Old Feb 4, 2008 | 08:53 AM
castrol's Avatar
castrol
How accurate is it?
The computer in the truck?
You know, the one that calculates I have 530 miles
left in the tank of fuel, but I rarely get more than
450 out of it.
Some trips, I can eek out a 20 to 21 mpg on the highway.
That is resetting the computer each and every time I fill up.
Has anyone checked the accuracy on that? I keep
forgetting to do the math when I fill up...maybe I
forget on purpose because I don't want my bubble burst.
~castrol
Old Feb 4, 2008 | 08:56 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You are talking about the LIE-O-METER. Some times mine will say (read) I have 750 miles to empty. Go figure. Do the math by hand, that is the only sure way to tell.
Old Feb 4, 2008 | 09:23 AM
Ballz_F250's Avatar
Ballz_F250
Must be nice to be able to claim 20 to 21 mpg. I'm lucky to get 12 mpg.
Old Feb 4, 2008 | 09:38 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If your truck is stock it's pretty accurate. The Distance to Empty (DTE) is usally close. When you say you only get 450 miles, is that until you fill it, or until it runs out? And by run out, I mean the engine stops running because the tank is empty. That's what the miles mean, how long you can go until the tank is dry, not just to where you should fill it.
Old Feb 4, 2008 | 10:27 AM
tazo's Avatar
tazo
https://www.ford-trucks.com/forums/5...ml#post3990543
Here is some reading for ya. It is in the 6.0 tech folder.
Old Feb 4, 2008 | 11:11 AM
castrol's Avatar
castrol
My biggest reason for asking...
We bought a 5th wheel camper and took it out to the State Park this past
weekend. It was a great trip and the computer let me know I was getting
about 13.5 up to near 14.1 mpg while in tow/haul mode. I thought this was
outstanding, but that when I started to question the validity.
Granted, it was mostly freeway towing. Very flat. Very easy. I reset it after
hooking it up and it started at about 8mpg and slowly climbed its way up to
14.1 by the time we got there. It had dropped back to 13.6 when we pulled
in the driveway last night.
Old Feb 4, 2008 | 11:29 AM
walleyeman's Avatar
walleyeman
My mpg reading is accurate. My truck is stock. If reset when filling up and not touched until the next fill up, it is accurate. Matches the hand calc exactly.
The DTE is Guess.
Old Feb 4, 2008 | 12:24 PM
redford's Avatar
redford
FTE Leadership Emeritus
It's as accurate as all the promises the presidential candidates are making to get you to vote for them.
Old Feb 4, 2008 | 12:32 PM
fivonut's Avatar
fivonut
Those DTE calculations are based on average MPG over a period of time. My G/F's Van always tells her she has 0 miles left when it's down to 1/8 of tank. If you spend time idling that will affect the calculations. It's not intended to be a tool, it's more of a gimmick.
Old Feb 4, 2008 | 12:36 PM
GregsSD's Avatar
GregsSD
When I got my 05 and it was all stock the meter would consistantly show 1mpg higher than the actual mpg. I would always hand calculate it to be precise and use the meter just for an estimate.
Old Feb 4, 2008 | 04:33 PM
davhut's Avatar
davhut
Mine has proven accurate - so far...
Old Feb 4, 2008 | 04:36 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Mine is pretty accurate on the mpg. I'm not sure how much I want to test the DTE!
Old Feb 4, 2008 | 04:57 PM
whjco's Avatar
whjco
My vehicle is stock and my Lie-o-meter usually shows about 2 mpg better than hand calculated.
Old Feb 4, 2008 | 07:47 PM
wadesmith's Avatar
wadesmith
Mine is always 15% higher than the hand calculated MPG. The miles to empty seems fairly accurate. When the low fuel light comes on, I have roughly 100 miles to empty, or somewhere around 5 gallons left. Fill the tank with 33 gallons in a 38 gallon tank. If I reset mine while driving the thing goes crazy! I have seen as high as 88 MPG when reset while driving.
Old Feb 4, 2008 | 08:20 PM
whjco's Avatar
whjco
Smile
Gee, why didn't I think of that? If I keep hitting the reset, maybe I'll be able to have that 100mpg Excursion that was in the post last week!
