1978 - 1996 Big Bronco
Vibration trouble
Old Feb 4, 2008 | 08:08 AM
tintow's Avatar
tintow
Unhappy Vibration trouble
I just bougt a '93 Bronco that pretty much sat for two years and this is my first 4WD and i seem to have a wicked vibration when i start to go 30 mph and above while on the pedal and also while i go uphill at any incline but if i let go of the gas the vibration seems to go away. I'm not sure that this might be a drive shaft problem or anything else in driveline. when it does this my power seems to suck. all i know it is not the wheels since they just got worked on. any suggestions will help especially if dont cost much. thanks
Old Feb 4, 2008 | 08:52 AM
Kemicalburns's Avatar
Kemicalburns
i would suspect either the ujoints are bad in the driveline or your tranny is shuddering of some sort. I would get the tranny serviced with new fluid and filter and see if it continues. if so then i would suspect the ujoints are bad.
does it feel like a possible missfire? how does the motor run?
good luck
battmanf16
22
Mar 11, 2020 11:36 PM
Jeff396
Jul 22, 2012 09:20 PM
dg416
1983 - 2012 Ranger & B-Series
Dec 24, 2011 04:30 PM
pit_of_pity
17
Mar 24, 2011 04:50 PM
jason1
Nov 18, 2008 06:03 PM
