Check Engine Light
Old Feb 3, 2008 | 10:14 PM
katiesdad7's Avatar
katiesdad7
Check Engine Light
I was driving to breakfast this AM and the check engine light came on. I have no idea what is causing it. I will take it to the dealer this week and let you all know. The vehicle has almost 16,000 miles on it. It is still under warranty.
It happened after I filled up the tank.
Old Feb 3, 2008 | 10:29 PM
Fugazi's Avatar
Fugazi
Bad gas maybe? At which station did you fill up?
Old Feb 4, 2008 | 12:38 AM
i eat hybrids's Avatar
i eat hybrids
BTW, if the stealership wants to keep ur truck over night and u dont want that, then take it to autozone. They scan codes when ur check eng light is on for free.
Old Feb 4, 2008 | 09:00 AM
VaSheriff's Avatar
VaSheriff
Could be gas cap related. Did you screw it on crooked maybe? Not tight? Take the gas cap off, put it back on and go through 3 thermal cycles to see if the check engine light will go off. This has happened on my Crown Victoria several times.
Old Feb 4, 2008 | 06:14 PM
XHunter's Avatar
XHunter
you need to read the code and that will tell you what you want to know............gas cap is a big possibility. you need to put a SC from Spartan in there.........it will haul but and you can read codes + better mpgs......
Old Feb 5, 2008 | 08:26 AM
katiesdad7's Avatar
katiesdad7
I was thinking of something like that but I only drive it about 5k a year. It's hard to justify the money for not driving it that much.
Old Feb 5, 2008 | 09:11 AM
njstevens's Avatar
njstevens
I agree check cap. If it is still reading a code find out what code it is and let us know.
2003f150xl
1997 - 2003 F150
Feb 3, 2009 10:12 AM
tenptbuck7mmmag
1997 - 2003 F150
May 6, 2008 10:18 PM
bmxerbrett
Jan 29, 2006 08:07 PM
gblakeney
Dec 10, 2001 10:32 PM
rsbeadle
Mar 22, 2001 10:55 AM
