2005 excursion
Old Feb 5, 2008 | 11:38 AM
r stene's Avatar
r stene
2005 excursion
I have a 2005 excursion 2wd that wanders all over the road. It is stock and has done it since new. Ha anyone found a fix?
Old Feb 5, 2008 | 11:55 AM
shadowdd's Avatar
shadowdd
Welcome to the forum, there is a lot of great advice here. As for the steering there are a few fixes that you can try:
Helwig sway bar
Steering gear adjustment to tighten steering
Check the tie rod and other vital linkage by putting the truck on jack stand (on the frame) and checking for loose parts on the front end. Grabbing the front tires on the top and bottom / sided to side and moving will check for a lot of problems.
This is just a start. I am sure that more people will chime in.
Thanks, Bryan
Old Feb 5, 2008 | 01:28 PM
i eat hybrids's Avatar
i eat hybrids
Did ur ex come with tow mirrors? THe reason i ask is because the tow mirrors where in the tow package. That would mean that ur truck didnt come with a sway bar. And their for u need one and that will keep ur truck from goin all overthe road.
Old Feb 5, 2008 | 01:31 PM
Monsta's Avatar
Monsta
Sit. Stay.
2WD never came with a rear sway bar.
More than likely the alignment settings are off. But Bryans link to the steering gear adjustment is an easy check & fix and doesn't cost anything.
How's your tire wear? Even?
Old Feb 5, 2008 | 01:47 PM
r stene's Avatar
r stene
Thank you guys very much.Yes the tires are wearing even and it should have the tow package.Has large mirrors and hitch.
Old Feb 5, 2008 | 02:03 PM
i eat hybrids
haha opps, i didnt see that in the orig post. But the 2wds never came with a sway bar? Even as a option?
Old Feb 5, 2008 | 02:05 PM
njstevens's Avatar
njstevens
Sway bar is the way to go for starters. Not all tow packages with the X came with sway bar. I had my uy put in a custom F450 sway bar fro cheaper then the helwig,but many folks on here will say helwig is the way to go when it comes to the sway bar. Do not buy F250 OEM sway bar what ever you do.
mrtris
New Member Introductions
May 2, 2017 12:43 PM
LPD
Sep 24, 2016 10:53 PM
Navigator777
Aug 31, 2016 05:35 PM
jimmyboy
Aug 11, 2006 01:20 AM
STROKE'IN
Jul 28, 2004 11:26 PM
