The easiest way to remove the bolts hold the water pump pulley on is to first hit the bolts with penetrating oil and then leave the belt on while you loosen them, this hold the pulley in place. After cracking the bolts, remove the belt, and remove the bolts and the pulley.
ok so im back at step one. belts off, now do i remove the large bolt between the pullet and fan? or do i remove something else 1st
