My truck, 97 F350 4X4 CC, is shredding serp belts. It's eaten 3 lately. It only takes the first rib off, or at least I catch it before any more go. It looks like the belt may jump on the pulleys and one of the lipped pulleys slices the belt. The tensioner is probably no more than 3 years old. Any suggestions? I will probably be slow with checking replies, internet is out at the house so I have to come to the library to check stuff.
Maybe the tensioner pulley or the idler pulley is siezing up.
Are all the pulleys lined up? The vacuum pump pulley can be installed too shallow causing this to happen.
most likely a pulley is out of alignment. take the belt off and check all the pulleys for excessive play. and use a straight edge to check the alignment
+1 Also make sure that the power steering pulley is installed properly and make sure that none of the pulleys are warped or damaged.
I had this problem once, but it turned out that it was my fault. when i installed the belt it was off just a tiny bit and eventually tore one rib off and thats how it stayed for probably a year and a half or more. only reason i replaced it was b/c it started to squeek at start up. like everyone said. check all the pulleys and make sure they are all aligned correctly and check them all for slack when you take the belt off again. the main pulleys i have noticed like to go out are the idlers, the A/C compressor and the vaccuum pump. these are the only pulleys my truck has ever had replaced and it will hit 300k miles in the next couple days. LoL
I heard there are 2 diferent belts somewhere. One is wider than the other. I could be mixing my vehicles up but maybe som one else can/will enighten me/us more.
Could be if he got a new alternator. the pulleys that come on them aren't the right ones. they are the 7 rib i think and you gotta change it out with your pulley. but he should notice that when he puts the belt on. i mean its right there in your face when you put the belt on
When my water pump was going out I had the same thing happen ,I would take the belt off and check out all the above and also grab the fan see if it moves at all.
Back at the library. Thanks for the tips. It is the A/C pulley. I took the belt off to check all of the pulleys and sure enough, the A/C pulley had some slop. I replaced the compressor about 2 years ago. A tech at the parts house I use told me to check the orifice tube. I didn't remember it being dirty when I changed it out, but I will pop it out and check it. Basically, he said if it is dirty, I probably should have changed the condenser before, had will have to change it out and replace the comp. Something to do with teflon clogging up the condenser, causing high head pressure, leading to premature failure.
I'll keep y'all posted.
Ford has a TSB on the belt shreding.they say replace the tensioner.
Article No.
03-21-14
10/06/03
FEAD BELT - WEARS, SHREDS, AND/OR COMES
OFF - VEHICLES WITH 7.3L DIT ENGINE AND 130
AMP ALTERNATOR BUILT 8/94 THROUGH 5/96
FORD:
1995-1996 E-350, F SUPER DUTY, F-250, F-350
Article 96-17-19 is being republished in its entirety as part of a consolidated 7.3L diagnostic aid booklet, and to update part information and vehicle criteria.
ISSUE
The Front End Accessory Drive (FEAD) belt may wear, shred and/or come off during deceleration.
ACTION
Replace the belt tensioner and the FEAD belt. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
1. Inspect the belt for rear edge belt wear and move the tensioner arm to see if it can be cocked out of position.
2. Check for a sticking or binding tensioner by moving the tensioner through its full travel.
3. If any of these conditions exist, replace the belt tensioner following the procedure outlined in the appropriate model/year Service Manual.
PARTS BLOCK
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 96-17-19
WARRANTY STATUS: INFORMATION ONLY
