starter clicks
Old Feb 4, 2008 | 01:26 AM
joewaldner's Avatar
joewaldner
why dont I need the spade connector?
Old Feb 4, 2008 | 01:33 AM
joewaldner's Avatar
joewaldner
if they eliminated the spade connector .... where does the wire on the truck attach to ?
Old Feb 4, 2008 | 06:34 AM
netscaner's Avatar
netscaner
They have eliminated the spade tab and put on a small connecting post instead.
You cut the spade connector off the end of the wire on your truck, and connect that wire with a nut on the post.
Old Feb 4, 2008 | 10:57 AM
quicklook2's Avatar
quicklook2
the spade connector was a source of corrosion.
a new starter the last time i bought one was just a little less than 100 dollars at advance auto.
not sure at napa but if they have cheapest starter, next more expensive and most expensive i would get one of the 2 more expensive.
good luck and tell us what happens after you get the truck started.
Old Feb 4, 2008 | 09:54 PM
Old_Paint's Avatar
Old_Paint
QL2, you got ripped. I bought a brand new (not reman) Motorcraft starter at Advance for about $65. ANY new or reman starter for these trucks will have the threaded post on the solenoid and a patch kit to splice to the OE wiring. There was a service advisory from Ford that prompted this move by starter rebuilders and manufacturers. A printed copy generally comes with the starter, but dunno if it's in ALL brands. I did get one with my Motorcraft, though. One of these days, I'll find it again, and scan it for posting in the gallery.
Old Feb 4, 2008 | 10:11 PM
quicklook2's Avatar
quicklook2
you got me thinking and when i found the receipt with tax it was just under $70.
it was for another 92 f150 with a 5.0.
Old Feb 9, 2008 | 11:33 AM
joewaldner's Avatar
joewaldner
well I bought a remanufactured one today for $156.47 with trade in..... slightly a bit more than $70 eh
Old Feb 9, 2008 | 12:17 PM
quicklook2's Avatar
quicklook2
it depends on where you shopped at.
did it fix the problem?
Old Feb 9, 2008 | 03:17 PM
joewaldner's Avatar
joewaldner
I went to 3 places, all in the same price range, so I bought the one were I buy most of my parts from
haha idk if I fixed the problem yet
its -42'C with the windchill outside lol
and my garage is housing my other truck .....
I have it bolted up and one of the wires attached, fingers went numb couldnt get the small one, Ill go back and try to get it done in about 20 minutes .... It's supposed to get colder out tonight
Old Feb 9, 2008 | 03:26 PM
quicklook2's Avatar
quicklook2
YIKES! that is cold.
i forgot you were in canada, the cdn dollar price is always more for you guys.
don't loose a finger out in the cold.
we are having a heat wave here in ohio, 40 degrees f. but dropping to below zetp in the next day or so.
Old Feb 9, 2008 | 03:46 PM
joewaldner's Avatar
joewaldner
I'll try not to ... lol Im going out again right now, see what I can do ... probably be back in about half an hour or so
should be better soon, I sold my truck in the driveway, so, as soon as its picked up the truck in my garage will take its place, and the newer one can be parked in there... lil warmer ... (no wind) lol
Old Feb 10, 2008 | 10:24 AM
joewaldner's Avatar
joewaldner
everything is atached and it turns over, but it wont start,
plugs and wires look new, block heater is plugged in
its been sitting for a little while, since 2006 I think (last registered in 06) , so it could just be old gas ..... right?
Old Feb 10, 2008 | 11:19 AM
  #28
quicklook2's Avatar
quicklook2
try starting fluid.
check fuel shut off switch.
fuel pump priming?
do you have spark?
Old Feb 10, 2008 | 11:23 AM
  #29
joewaldner's Avatar
joewaldner
dont have sarting fluid
fuel pump you can hear come on for a few seconds (about 2) when you turn the key
where is the fuel shut off switch :S
Old Feb 10, 2008 | 11:26 AM
  #30
quicklook2's Avatar
quicklook2
behind the pass. side kick panel.
try starting fluid.
