460 knocking
Old Jul 15, 2001 | 05:37 PM
therigwelder's Avatar
therigwelder
460 knocking
my 460 makes a fairly loud knocking noise coming from the lower end (this problem just started)sounds like a rod knock. i pulled the pan dropped the rod caps and pulled the bearing i found 020 oversize bearings with wear down to the copper underlayment but i dont beleive this could cause a rod to knock all of a sudden but while i was in there i reached into the bottom of the chain cover and the chain felt real slack could this make a knocking sound? any knowledge on this subject would be helpful
Old Jul 15, 2001 | 06:32 PM
whomrig's Avatar
whomrig
460 knocking
Timing chain slack can cause the knock also. had this happen to me once.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Jul 17, 2001 | 10:03 AM
classic79's Avatar
classic79
460 knocking
Old Jul 17, 2001 | 08:54 PM
proud owner's Avatar
proud owner
460 knocking
yes, a slack timing chain will cause knock too.. the slack gets picked up, then thrown out again and flings the chain around, sometimes hitting it on the cover...causing the knock!
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
460/C6 transplant @ 389hp/491 lb.ft.
14.29@103.8, 13-14 mpg heheheheheh
Old Jul 18, 2001 | 10:13 PM
bigsnag's Avatar
bigsnag
460 knocking
I just rebuilt my 460 and the bearings were pretty worn, although they were not down to the copper. It didn't hold very good oil pressure when warm, but it did NOT knock. BTW, the timing chain was so loose I think I could have taken the chain off without removing the gears. I would really suspect that the sound is a rod knocking in your case.
cmoses
Feb 21, 2016 06:43 PM
Lexrex
May 4, 2015 09:32 PM
oldblue89
Jan 6, 2013 10:01 PM
79Bronk
May 31, 2011 03:53 PM
scoutpup99
13
Feb 8, 2010 06:08 PM
