I just installed a South Bend SMF in my 89 IDI with the ZF5. The problem is that anytime the clutch is released there is what sounds a lot like a rod knock coming from the bellhousing area. This is especially noticeable as the truck is idling without a foot on the clutch. The knocking increases in rate as rpms go up. If I just put slight pressure on the clutch pedal - the knocking goes completely away - I guess because the throwout bearing is pressed up against the pressure plate fingers. I spoke with South Bend about it and they suggested replacing the clutch fork - as it could be worn. Does this sound like the culprit? Or is it possible that I slid the clutch fork onto the bearing the wrong way? I went ahead and ordered a new fork anyway.
sounds like it is the throwout bearings itself. they like to make kind of noise when they start getting old, and worn out. it could be possible that the fork is too close for also being worn out, but i really doubt you put in backwards. it really only goes in one way, and by stepping on the pedal means it is not the for but the throwout bearring. i would do that first.
It is a new bearing supplied by South Bend, I would like to hope that a bad bearing from them would be unlikely considering their product's quality/expense.
But is it possible that I put the fork onto the bearing wrong? In other words, does the bearing need to be rotated at all to fit a certain way snugly on the fork or does it simply go onto the bearing in any way?
ya. one side is round the other straight. rounds side goes against fork, and metal rotating face that spins goes against the clutch. check to see that your slave is moving out and in all the way
I am sure I got it on the quill/input shaft correctly however, I don't know if I slid it onto the bearing correctly. Is there a certain way it goes? I mean I put it onto the "void/recessed" part of the bearing, but do I have to rotate the bearing a certain? Do you have to rotate the bearing a certain way to fit properly onto the fork (with no play/knocking) or does it just rotate within the fork?
My 1990 F250 was doing the same thing, noisy at idle, and noise would completely go away if you just put a light pressure on the clutch pedal. But mine has 377k miles on the original driveline, never touched, original clutch as well.
Could be the fork or the new throw out bearing. Even the highest quality brands have defects sometimes.
