custom bedcovers?
Old Feb 2, 2008 | 04:36 PM
going slow's Avatar
going slow
custom bedcovers?
has anyone made there bed covers? if so do u have and plans or (blueprints) ....and what materials... id kinda like to have a soft cover but hingable...somthing along those lines...
Old Feb 2, 2008 | 05:45 PM
mechmagcn's Avatar
mechmagcn
I had posted on here about purchasing a Ford van and someone suggested using the roof panel to make a bed cover, looks like it would be doable.
Old Feb 2, 2008 | 06:02 PM
Randy Jack's Avatar
Randy Jack
I made a hard tonneau with a light on the inside of it. My gallery pretty much illustrates how I built it.
https://www.ford-trucks.com/user_gal...&albumid=16003
Old Feb 2, 2008 | 08:55 PM
56panelford's Avatar
56panelford
Great work there Randy, I really like the way that it makes it look lower and wider and as usual your gallery rocks.
Old Feb 2, 2008 | 09:42 PM
going slow's Avatar
going slow
yeah thats kinda what im thinking of...somthing like what randy did...i did somthing simular on an s10 the truck was white so i used white vinal and i also used alum. for the frame and sheeting just to keep it light...
Old Feb 3, 2008 | 08:06 AM
Truxx1956's Avatar
Truxx1956
Talking
Mine is alot like Randy's but mine leaks like a screen door on a submarine!! I'm goin to rework mine completely before this year's show in Pigeon Forge. I'm goin to weld up an aluminum frame and cover it, BUT this time I'm goin to make it go to the top of the bed, and hang over the edges. I'll have to make a "flap" hang down to cover from the bottom of the bedcover to the tailgate. They make fiberglass ones that do that, but they are very pricey!!
The 2 good things about doing it this way is it will SEAL!! and it will give me about 4" more bed depth more room for luggage and stuff on long trips.
Old Feb 3, 2008 | 07:39 PM
economan's Avatar
economan
i did one for my econoline, 1 inch square tubing with vinyl stretched over it and snaps down on the underside and hinged with set of tractor linch pins as hinges, it sits flush with the tops of the bedrails, it is far from watertight but seldom goes out in the rain.
there are no shocks, checks or stays, it simply folds up and rests on the rear drip rail of the roof.
when i wanna haul stuff just undo the snaps pull the pins and lift it off.
mikie
near ottawa canada
58 merc panel 64 econo p/u
Old Feb 4, 2008 | 01:03 AM
rustfarmer's Avatar
rustfarmer
I haven't got around to that point yet but I have some food for thought......I have been to an accident scene where a later model truck was involved. It had a aftermarket fiberglass bed cover. The truck was rear ended pretty hard. The impact drove the fiberglass bed cover thru the cab and killed the driver. I'm not trying to bum anyone out. But, something to consider when building our bed covers is what would happen if the truck was hit from the back.
rustfarmer
Old Feb 4, 2008 | 06:55 PM
hiwy50's Avatar
hiwy50
Just slipped out and took picture of my home made bed cover. Its dark out but you can see I made it fit the inside of the bed. 3/4 in alum. frame, 4 ft. wide, with two cross pieces. Glued polished aircraft alum. on outside with 3/4 in foam between the skins. Used 7/8 in. I.D. channel adjusted so there is a 3/16 in. gap all around. Not too expensive, $178.00 for materials. Cost more to have it painted.
Guess I am not smart enough to add pictures.
