Modular V10 (6.8l)
Howling noise
Old Feb 1, 2008 | 08:38 PM
hang10's Avatar
hang10
Howling noise
In the cold weather, after the truck is warmed up. When in lower RPM ranges some times, the intake or something will howl, really loud. It is only when the weather is around 45F or below. It has been doing it pretty much since new, just never took it in because it only happens when cold. It goes away once the RPMs get up into driving range, 1500 or so. It usually happens when going into reverse, or coming to a stop in 1st (manual trans), then will continue while at idle in N. Goosing the gas will usually not stop it but will sometimes. I have tightened all there is to tighten, so I don't think it's a leak. Just odd that it is temperature Dependant. Any help would be appreciated.
Old Feb 2, 2008 | 02:23 AM
swann79's Avatar
swann79
Wow that's a good one... never heard of it. Several things come to mind, but don't add up when you say it's been doing it since new. Good luck!
Old Feb 2, 2008 | 04:17 AM
Monsta's Avatar
Monsta
Sit. Stay.
Wonder if it's the steering fluid pump. They are know to be quite noisy when cold. Sometimes a switch to synthetic PS fluid in it helps quiet it down.
Old Feb 2, 2008 | 07:26 AM
swann79's Avatar
swann79
Well all of my newer Fords have had that "power steering" whine, but it only lasts a few seconds after starting... hang10 says that this noise comes after the truck has warmed up.
And that ps whine usually doesn't hit 'till the temps get around zero...
Old Feb 2, 2008 | 08:36 AM
hang10's Avatar
hang10
I've lifted the hood before and am 99% certain that it is intake related.
Old Feb 4, 2008 | 06:31 PM
super 6.8's Avatar
super 6.8
I had an idle bypass valve do the exact same thing on an explorer. Loosen it up and move it around to see what happens. You can start it up with the bolts loose and then move it around to see it the noise goes away or changes pitch. I ended up replacing it and the noise went away.
hang10
Jun 19, 2015 12:58 PM
motopsyko32
May 30, 2012 06:40 AM
Explorer Freak
Feb 15, 2011 07:26 PM
aaronhuck
Jun 23, 2006 03:43 PM
wpcol
Sep 8, 2001 06:34 PM
