Transmission Lube:
Tranny Fluid
FORD CAR
Transmission, Oil,
RAD, 80WT,
HEH, 80WT,
RUG O/D, 80WT,
SROD, 80WT,
RAP, 80WT,
T5, ATF,
T45, ATF,
RKE, ATF,
MTX, ATF,
MTX75, ATF,
M5TX, ATF,
FORD TRUCK
Transmission, Oil,
FM132, 75W90,
FM145, 75W90,
FM146, 75W90,
M5R1, ATF,
M5R2, ATF,
NP435, 50WT,
RTS, 80W90,
RUG, 80W90,
SROD, 80W90,
TREMEC, 80W90,
T18, 80W90,
T19, 80W90,
TK4, SYNTHETIC 75W90,
TK5, SYNTHETIC 75W90,
ZF S5-42, SYNTHETIC ATF,
ZF S5-47, SYNTHETIC ATF,
ZF S5-47M, SYNTHETIC ATF,
ZF S6-650, SYNTHETIC ATF,
FORD TRANSFER CASE
Transmission, Oil,
BW1345, ATF,
BW1350, ATF,
BW1354, ATF,
BW1356, ATF,
BW4404, ATF,
BW4405, ATF,
BW4406, ATF,
BW4407, ATF,
DANA28, ATF,
NP203, 30WT,
NP205, 80W90,
NP208, ATF,
NP271, ATF,
NP23, ATF,
Lou
The thing about GL-4 and GL-5 oils eating up blocker rings and other brass is only a problem where the trans oil gets up to about 250 degrees and above. This came up on the MSN Flathead board a few years ago. The typical scenario where it became a concern was on a modern diesel Dodge dually 1-ton hauling a 10,000 lb trailer through the mountains in the summer at high speed -- conditions not likely on our trucks. Their trans oil temps can get up iunto the 300's!! So they need a cooler. The GL-4/5 oils have an ammonia (amine) compound that gets reactive with copper at the higher temps, but is pretty benign at normal temps.
Would not mess around with synthetic oils in our old trucks, either drive train or engine.
