Offroad & 4x4
Winch plate recomendations
Old Feb 1, 2008 | 04:38 PM
blakeusa's Avatar
blakeusa
a 77 f150 with stock (new) front bumper. Looking for recommendations on winch plate that I can use with the stock bumer- what can I do to keep front bumper.
have a new 9000lb Superwinch that I want to get installed.
thanks
Old Feb 1, 2008 | 05:15 PM
Ryan50hrl's Avatar
Ryan50hrl
front reciever hitch and a hitch mount....
Old Feb 2, 2008 | 02:29 PM
rebocardo's Avatar
rebocardo
Box the inside of the frame under the flanges with 1/4" channel steel for 6-8" front to back, then mount a 3/8" piece of plate steel on top of the frame rail (will require cutting your grill) to mount the winch to. Bolt trough the plate/frame/backing steel with 5/8" grade 8 bolts.
I think that is what is recommended (the 3/8" plate steel and 5/8" bolts) for your winch or close to it.
I think (3) 1/2" grade 8 bolts each side would be enough (certainly the drill bits are cheaper) and would leave more of the frame rail undamaged, but, that call is up to you.
If I was going to mount a winch, I would work some tow hooks into the setup.
Greg5OH
Dec 16, 2014 11:38 PM
blacklab1
Feb 19, 2012 10:55 AM
akparker1
Jun 7, 2009 02:53 PM
makomarine
15
Mar 11, 2008 11:40 PM
shooter666
Aftermarket Products
Jan 9, 2004 10:45 PM
