Sponsored by: Auxito
Superchips power programmer
Old Feb 1, 2008 | 11:25 AM
jlmotox's Avatar
jlmotox
I have a 02' Screw 4x4 4.6l 65,000 miles.
I was wondering why they say to use 91 octane fuel when using the Tow/performance and High performance settings? Is this just to gain top performance with the tune? I forgot I put the tow/performance tune on my truck while filling up with 87 octane and I didn't notice any ill effects like running lean (pinging/detonation) or fault codes, I ran about a half tank before I realized it...oop's. I have since switched back to the 87/economy tune just in case. I would like to go back to the Tow mode with 87 octane because I really liked the low end torque for around town. (alot of hills out here).
Old Feb 1, 2008 | 12:19 PM
92merc's Avatar
92merc
I sure thought it was because the higher tune advances the timing a fair amount. You should have had some pinging without it.
You notice any power difference when dropping back to the 87 tune? Only reason I ask is because the tune changes the shift points as well. So maybe you weren't on the throttle enough to see the power change. You're only seeing transmission changes.
I don't have a tuner, so I'm only throwing out ideas here.
Old Feb 1, 2008 | 05:01 PM
jlmotox's Avatar
jlmotox
That's what I thought that the timing and fuel curves were the difference in tunes...no noticeable pinging/knocking...but I also am running the truck unloaded, I would assume I would get pinging with it loaded up though. I have not tried the 91 performance setting with the 87 gas...and don't think I will.
There was a loss of power when I changed back to the 87 economy tune, and I want it back on the cheap gas. lol but I don't want to damage the engine either...
deathinc_7
Modular V10 (6.8l)
Jun 17, 2016 08:29 PM
pappy19
2004 - 2008 F150
15
Dec 20, 2011 09:50 AM
svo121
Aug 31, 2011 08:41 PM
lariat97
Tennessee Chapter
Mar 3, 2007 07:36 PM
