Sponsored by: Auxito
2001 F150 4x4 Variable Wheelbase?
Old Jan 31, 2008 | 09:50 PM
whalerron's Avatar
whalerron
This is a question for somebody out there who knows the alignment measurements for the 2001 F150 4x4. Is the wheelbase the same on the left and right sides? I have been told that the left side is 139" and the right side is 137.5" wheelbase. Is this correct?
Thanks.
Old Jan 31, 2008 | 11:31 PM
LxMan1's Avatar
LxMan1
I've never heard that. Why would they be different?
I'll measure mine when the weather breaks.
Old Jan 31, 2008 | 11:38 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
I have heard thats is what the rear axle is on some of the supercrews, just outside to the center pumpkin... but im not sure if i belive it or not.
Old Feb 1, 2008 | 01:09 AM
LastSplash's Avatar
LastSplash
Assuming that the wheelbase is measures from the center of the front axle to the center of the rear axle, the only way one side could be shorter than the other is to have the rear axle crooked and/or the tie rods on the front are set to keep the front wheels crooked. If both the front and rear axles were crooked the truck would crab walk when driving straight, if only one axle were crooked you couldnt keep tires on the truck.
Old Feb 1, 2008 | 06:40 AM
whalerron's Avatar
whalerron
I was told that the two sides are different because of something to do with the way the truck suspension is layed out and aligned. Supposedly it is this way by design. This sounds really weird to me and I wanted somebody to look this up in the alignment specs books.
ethomps
Aug 27, 2015 09:35 PM
NTENSE
Mar 23, 2014 06:10 AM
kell2784
Nov 8, 2009 08:30 AM
flhhc
Jul 12, 2008 01:46 PM
Randy
Dec 2, 1999 10:20 AM
