Rear spring help....
Old Jan 31, 2008 | 07:47 PM
msb71's Avatar
msb71
A little under two years ago when I got my truck the rear springs were sagging a bit, so I installed a Long ADD-A-Leaf, this raised it back up to where it should have been, It was pretty stiff to boot ,loved it.
Problem now is that now they are very bouncy , almost as if the add-a-leaf has given out, I knew it would eventually , so my question is : should I get a set of rear springs for a F-250 or even a f-350, my springs are 3inches wide (4X4), or a air bag system?
I am leaning towards the new springs, I have looked all over the internet at different setups and there are many, I need something that can handle some weight , my truck is loaded down on a daily basis ( materials , ladders, etc).Pulls Camper in the summer (6000 lbs.)
Any suggestions would be appreciated.
Mike
Old Jan 31, 2008 | 09:14 PM
compaddict's Avatar
compaddict
I did the JCW 2k springs and they worked perfect for me on my old 1991 f150 4X4.
http://www.jcwhitney.com/autoparts/P...009172/c-10614
Vince
Old Feb 1, 2008 | 05:06 AM
msb71's Avatar
msb71
Looks pretty good, would the 2400lbs be better?
Mike
Old Feb 1, 2008 | 10:41 AM
compaddict's Avatar
compaddict
Probabaly would be a better for you going a bit higher. If you find out it is too stiff, springs are cheap enough to change!
Vince
Old Feb 1, 2008 | 11:11 AM
Surge08's Avatar
Surge08
Make sure the shackles were not broken very commen
Old Feb 1, 2008 | 05:12 PM
fash's Avatar
fash
If you still have the same ride height, chances are that your shocks may have worn out. Isnt that what stops the bouncing around
Old Feb 1, 2008 | 05:35 PM
Itch71's Avatar
Itch71
I'd check shocks too first
Old Feb 1, 2008 | 05:55 PM
Van Zant's Avatar
Van Zant
i got rear springs from broncograveyard and they gave my back quite a hike. nice ford part for cheap
Old Feb 1, 2008 | 06:26 PM
msb71's Avatar
msb71
Shocks are pretty new, the springs sag a little under weight. When I put the add-a-leaf in you press the truck down a little but now it goes down fairly easy so I am sure it is the springs, .
Will the new springs lift it any? I don't want to much rake back there but I want a stiffer ride. Appreciate the comments so far keep em coming.
Mike
Old Feb 1, 2008 | 11:48 PM
kcb37's Avatar
kcb37
I have a good question. My truck is in my sig. Now being the heaviest 3/4 made in 89 I think my truck should sit better with my trailer and Camaro. I do know it did at one time pull a 5th wheel so this is no suprise.
My question is how new of springs can be pulled to fit the body style. I know up to 96, but will springs off a newer truck fit?
I just don't want to spend the money and end up with more wore out springs.
Chaos 6 Superduty
Mar 7, 2010 05:18 PM
68-F250-4x4
Feb 26, 2008 09:54 AM
foxracer800
16
Jun 4, 2006 07:50 PM
JohnT
Apr 13, 2005 05:51 AM
Primered86XLT
Jan 21, 2005 07:45 PM
