clicking sound under dash
Old Jan 31, 2008 | 06:53 PM
chris-danielle's Avatar
chris-danielle
hello,
my wife's '99 Explorer Limited is making a clicking sound under the dash. The sound is coming from the passenger side, and doesn't seem to be related to the A/C or heater, as both work fine. If i open the glove compartment, and reach back inside the dash, I can feel something clicking, but I can't see exactly what it is. Any suggestions?
thanks in advance!
Last edited by chris-danielle; Jan 31, 2008 at 06:59 PM. Reason: non-descriptive title
Old Jan 31, 2008 | 07:23 PM
antony25's Avatar
antony25
Sounds like a bad blend door motor.
Old Jan 31, 2008 | 11:12 PM
chris-danielle
so you think it must be related to the heater and/or A/C?
Old Feb 1, 2008 | 12:42 PM
chris-danielle
Must the entire dash be removed to find the problem?
Old Feb 1, 2008 | 01:20 PM
marragtop's Avatar
marragtop
Before pulling things apart, try isolating the problem. If you think it's climate control related disconnect any fuses that are part of the circuit to see if the problem goes away. If it goes away, then you know it's climate control related.
Old Feb 1, 2008 | 01:34 PM
chris-danielle
thanks, good suggestion. I'll check today and let you know the result.
Old Jun 5, 2008 | 10:40 PM
chris-danielle
strangely, the clicking has gone away, and the heat and a/c work great!
Now i'm trying to figure out a completely new problem with the same truck! bad injector? # 3 misfire is all i have to go off!! (wish all i had was the damn clicking sound)
Old Jun 6, 2008 | 02:04 PM
Bob 79 supercab's Avatar
Bob 79 supercab
My '95 2 door had a intermitent click and it turned out to be the turn signal relay but it was on the drivers side.
Might be worth checking though.
Bob
erik_bishop
Apr 4, 2024 11:51 AM
winnie.j
Sep 23, 2016 12:34 PM
r1819m
Dec 9, 2015 07:06 AM
Moto52
13
Oct 7, 2011 08:17 PM
jessccs
Jun 13, 2006 04:27 PM
