Sponsored by: Real Truck
Won't start
Old Sep 23, 2016 | 10:48 AM
winnie.j's Avatar
winnie.j
Won't start
I have a 2003 Ford F450 super duty xl. At first there was a loud clicking sound coming from under my dash. I charged the battery up and the sound went away but the truck will fire up but not turn over and start. I thought maybe it could be the relays but the clicking sound quit.
Old Sep 23, 2016 | 11:27 AM
Wingit929's Avatar
Wingit929
Check and clean the terminals but I would bet you need a new battery. Take it out and have it checked.
Old Sep 23, 2016 | 12:34 PM
droldsmorland's Avatar
droldsmorland
A 13-14 year old vehicle very likely needs to have all grounds and positives cleaned and resealed. From the battery(s) through the solenoid down to and including the starter connections. Look for any little ground straps coming off the secondary (main larger) cables and do the same. And as mentioned have the battery and charging system load tested.
The system will work much more efficiently if it doesn't need to overcome all the resistance of dirty connections and bad battery cables.
Dillion Marshall
1978 - 1996 Big Bronco
Mar 11, 2015 10:21 AM
braveric1
27
May 10, 2014 11:06 AM
Indy443
Apr 10, 2014 11:19 AM
James Hiller
19
Mar 26, 2014 07:24 AM
johnkirk
May 4, 2010 04:45 PM
