Who's on 3rd?
Old Jan 31, 2008 | 04:06 PM
Faroutman's Avatar
Faroutman
Who's on 3rd?
Ok I have been busy with school work as of late so the 65 F100 has been sitting for about a month or so, I recently started driving it to work and school again as I have replaced the entire brake system and the truck is once again safe to drive.
Here is the problem, for what ever reason, when I slow down below 40mph 3rd gear disapears. Truck is 352 with 3 on the tree, if someone cuts me off and I need to hit the brakes as soon as I go below 40 I get a grinding noise and truck is in neutral, all I need to do is push the cluth and go back into 3rd and I have no problems but its an annoying new problem, as I mentioned in an earlier post I was raised and Pontiacs and Dodges so Ford still holds many mysteries to me and I have never before owned a 3 speed.
I've called around and most places like CarX refsed to look at it as my truck is too old for them, I do have an apointment to go to Edwards Transmissions in Indy in 2 weeks but I was hoping to find a quick fix while I wait.
Thx for your time
Old Jan 31, 2008 | 04:23 PM
airharley's Avatar
airharley
This might sum it up a tad...
http://www.usatransdoctor.com/ManualTrans.htm#5
I also found this that point to internal failure...
http://autorepair.about.com/cs/troub...a121501a_5.htm
and on to bad syncros...
http://www.econofix.com/mtrans.html
If you are mechanically inclined a manual transmission is pretty simple to rebuild as long as you have the bearings, syncros, races, and seals. I have rebuilt a few over my time and the hardest thing is cleaning the gear oil off your clothes afterwards. Just stay out of the house or cab until you strip all your stinky clothes off. Otherwise you will be smelling it for weeks.
Old Jan 31, 2008 | 05:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Just reading this post brings the gear oil smell to mind. Once smelt...never forgotten!
All the parts to fix the trans are available from NAPA.
The usual cause when the trans pops out of gear when slowing down: worn 2-3 syncro brass blocker rings.
Old Jan 31, 2008 | 08:11 PM
daveengelson's Avatar
daveengelson
Not an authority, if understand correctly, transmission works find in 3rd gear and problem developes when speed is reduced to below 30mph. Curious whether or not you have the 3 speed w/ overdrive. If so, suggest check overdrive cable adjustment. Also, check the gear shift linkage, want the linkage to move freely and engaging. Finally, check clutch adjustment, and linkage. .
dave
bryanswens
Jun 9, 2009 11:09 AM
Big John Hance
Jan 30, 2008 07:15 AM
sprayed
1978 - 1996 Big Bronco
Jul 31, 2005 04:33 PM
Truck123
Nov 11, 2004 07:26 AM
460lover
Arizona Chapter
Jul 16, 2003 01:35 PM
