Defrost = Poor MPG??
Old Jan 31, 2008 | 11:43 AM
tobyw's Avatar
tobyw
Took a round trip of about 150 miles yesterday, one that I make every 6 weeks or so. Anyhow, the only difference on this particular trip was that I left my HVAC set on "vent" instead of "defrost", thus my A/C compressor was not cycling... I was greeted with just over 9mpg, as opposed to my typcial 7. Now, I fully understand that the compressor causes some extra parasitic drag on the engine, but 2mpg worth??? Is there some way to check the compressor for excessive drag or anything like that? I have to admit I felt no difference in power or anything like that, but this truck has NEVER given me 9mpg before.
And no, it's not differnent fuel (same tank from prior 150 trip) or different driving conditions (same highway, same 68mph cruise setting)... This is, however, the FIRST trip I have taken where I was not using an HVAC setting to engage the compressor.
Old Jan 31, 2008 | 11:51 AM
44dwarf's Avatar
44dwarf
Yup its a ford thing.
Seems some dumby engineer years ago made it so the A/C is on any time the selector is in the defroast position! So your sucking power by useing the A/C.
Now I've had this argument on how dumb and wastefull this is with many poeple and while they all make the point the windsheild defrost faster with it, no one has been able convince that its a must as cars / truck with out A/C get the job done just fine.
I pulled my wire plug off the compressor at the 1st snow.
44Dwarf
Old Jan 31, 2008 | 11:52 AM
V8NAMESE's Avatar
V8NAMESE
MAGIC! Actually I have no idea, but I'd gladly take an addt'l 2mpg's anyday
Old Jan 31, 2008 | 12:28 PM
Conanski's Avatar
Conanski
The higher the engine rpm the more energy required to rotate that AC compressor. At the 1800-1900rpm my 3.55 geared 5.8 1/2 ton runs at while going 70mph in OD I see no difference at all with any climate control setting, but at 3000rpm when it drops out of OD the drag from the compressor is substantial, it would definitely hurt milage if I had to turn those rpms all the time.
Old Jan 31, 2008 | 12:34 PM
capn kirk's Avatar
capn kirk
i think all cars us a/c for defrost to take the moisture out of the air
Old Jan 31, 2008 | 01:01 PM
MisterCMK's Avatar
MisterCMK
The air temp will also make a difference in compressor load.
Old Jan 31, 2008 | 01:15 PM
merlynr's Avatar
merlynr
28percent better mpg wo ac? 150 miles isn't very far for a test of mpg. 460 shouldn't decrease that much, especially with that gear ratio. Maybe headwind/tailwind difference.
Old Jan 31, 2008 | 03:05 PM
quicklook2's Avatar
quicklook2
you should not need defrost for an entire trip.
Old Jan 31, 2008 | 04:43 PM
GrimOne's Avatar
GrimOne
My .02
I'm getting 10.5 out of my 460 with it off
I'm getting 10.5 out of my 460 with it on
go figure
Old Jan 31, 2008 | 04:55 PM
Big_Man_Brad's Avatar
Big_Man_Brad
Well for some reason i'm getting very bad mpg with my truck now...I was getting almost 11 and now i'm getting 9.3 i just don't now...I know its like 10 degrees colder....The last 2 tanks i got the same....
Old Jan 31, 2008 | 05:43 PM
detailsbydan's Avatar
detailsbydan
Sounds about right, that is why if you have an older vehicle that doesnt run the a/c when in defrost and you turn it on the windows will clear faster and will stay clear for longer periods of time due to the drier air in the cabin.
Old Jan 31, 2008 | 06:07 PM
MisterCMK's Avatar
MisterCMK
Part of the problem is that winter gasoline makes your fuel mileage go down. Cold starts also suck down the fuel.
Old Jan 31, 2008 | 06:33 PM
detailsbydan
yes, this too, i didnt think to mention that.
Old Jan 31, 2008 | 07:03 PM
quicklook2's Avatar
quicklook2
go figure
hahahahahahahahaha
you got rep points for that post.
hahahahaha
Old Jan 31, 2008 | 07:24 PM
fmr9's Avatar
fmr9
I don't believe your A/C compressor alone is causing that much gas consumption. Is it possible that you have a vacumn leak in the climate control system that only happens when defrost is selected? I know if there is a big leak, the default setting for the flapppers is defrost. I can't think of where a leak would be, that only happend on defrost. An easy test would be use a hand pump to draw a vacumn with the engine off on the line going thru the heater box. Then switch to defrost and see if it will hold a vacumn.
Good luck Frank
