1996 351 hard starting
Old Jan 30, 2008 | 07:49 PM
Scott B's Avatar
Scott B
I read a previous post about a V-10 not wanting to start. The reference to the IAC valve being the problem sounded logical. When my '96 351 is cold it has to crank a while then will idle at 300-400 for a few seconds then jump up to about 1000 rpm. Warm starts seem to be fine. It just started doing this about 3-4 weeks ago. My dealer replaced the fuel pressure regulator and I've replaced the spark plugs. Neither helped. Does this sound like the same IAC valve problem? Where is it on my '96 351? And is this a part that NAPA/Auto Zone/Car Quest will have or is it dealer only? I've got 205,000 on this baby, bought it new and still love it.
Old Jan 31, 2008 | 05:55 AM
HemiEater's Avatar
HemiEater
pull codes before you replace anything. Could be this could be that.....
Old Jan 31, 2008 | 07:39 AM
Conanski's Avatar
Conanski
That sounds like a weak spark actually, either a weak coil or failing wires. All these can be measured with a DMM.
contento
Modular V10 (6.8l)
27
Nov 7, 2013 10:35 PM
Jlckb5
Nov 7, 2011 07:50 AM
Thor2911
Feb 4, 2011 08:47 PM
ghkramer
Modular V10 (6.8l)
Dec 5, 2005 12:58 AM
atesml
Nov 12, 2003 08:52 AM
