IAC Change didn't work...HELP
Old Nov 10, 2003 | 09:29 AM
atesml's Avatar
atesml
Unhappy IAC Change didn't work...HELP
Well I changed the IAC since because my 96 4.0 V6 Exxplorer was Stuttering and stalling, and my normal mechanic said there was nothing wrong with the O2 sensor or the EGR valve. The guys at Meineke said the same thing as well.
None the wiser since my problem seemed much like the problem in the IAC Sticky. I changed the IAC. Had a tune-up this summer.
Now when I try to start the car is sounds like the battery is maybe running low. Any ideas before I give up and take it in for the dealer to put on part after part until the stumble accross the right fix.
Old Nov 10, 2003 | 11:35 AM
99Xplr's Avatar
99Xplr
Could be the battery, the alternator, the starter itself, the selenoids, or the main cable that runs to the starter. When did you have the battery replaced. (of course I am assuming that you had the battery replaced at some point since 96) If the battery is old, then it might not be holding a charge. If the alternator were not genterating enough power to recharge the battery you could have problems starting the truck. Do the lights dim exsesivly when sitting at idle? If so, could chance its the alternator. When you had the tune up done, where the ignition wires replaced? A bad wire could also be a problem. That should give you a few things to check. Let us know what you find, and if none of the above is it, I'm sure we can help you locate the problem.
Old Nov 10, 2003 | 12:14 PM
aletheuo's Avatar
aletheuo
Just went through the exact same thing with my aerostar. After replacing IAC it turned out to be ECC engine temp sensor. Get it up to normal operating temp and then disconnect the sensor. See if that clears it up. It did for me. See my thread https://www.ford-trucks.com/forums/s...hreadid=165900 - maybe it'll shed some light.
Old Nov 12, 2003 | 08:52 AM
terestron's Avatar
terestron
Exclamation
my aerostar did the same thing....it started like the battery was low...it was the starter going.....replaced the starter and it starts fine now.....
WB4IUY
Escape & Escape Hybrid
Jul 13, 2014 01:38 PM
tonyford
Mar 2, 2013 04:40 PM
Jlckb5
Nov 7, 2011 07:50 AM
muddydawg
Nov 4, 2009 04:01 PM
scrapyardking
1983 - 2012 Ranger & B-Series
Mar 18, 2008 08:29 PM
