Brake Help
Old Jan 30, 2008 | 06:27 PM
just another truck's Avatar
just another truck
Brake Help
All right, here we go. more the two months ago i went after a pulling to the left when i hit my brakes.. pulled the wheels off, looked, asked the wife to pump the brakes, both calipers moved about the same. so i pulled them off to see how they woul collapse with a c clamp. no problem either side. i then checked the slide pins, the looked great. i then replaced the pads
4 days later i started pulling again, i inspected brake lines, bleed brakes.
pulled again 4 days later, i let it go for a month, started thinking old school, pulls to the left, replace the right, i am pulling again, three days later..
i am lost
Old Jan 30, 2008 | 06:51 PM
clintbonnie's Avatar
clintbonnie
Ball joints going bad or steering linkage or steering box wear, maybe?
Old Jan 30, 2008 | 06:53 PM
just another truck
only pulls when i hit the brakes, so, i am guesing not, doesnt mean i wont go after them again. any thouhts on the anti lock control
Old Jan 30, 2008 | 07:12 PM
powerstroke1869's Avatar
powerstroke1869
hmm thats weird i had the same problem but i had to replace my caliper bracket because my slides would not move... but as soon as i did that the problem was gone
Old Jan 30, 2008 | 07:15 PM
just another truck
i am beating my head on this one, i used to be certified in brakes, couldnt prove it today
Old Jan 30, 2008 | 07:22 PM
powerstroke1869
lol yea sorry i couldnt be more of help
Old Jan 30, 2008 | 07:24 PM
just another truck
I appreciate the support!!
Old Jan 30, 2008 | 09:36 PM
Mike Norwood's Avatar
Mike Norwood
i had an f-150 that was doing the same thing even the slide pins looked good. i replaced the slide pins and the problem went away. hope this helps lol.
Old Jan 31, 2008 | 09:35 AM
just another truck
Sorry, doing two things here, 1 bumping it, 2, asking again, what do you think of a bad hub bearing causing this??? I dont, but it was suggested?
Old Jan 31, 2008 | 09:44 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Could it be a bad break line? Rubber seperating inside and causing low psi. It would have to be on the right side I would think.
Old Jan 31, 2008 | 10:23 AM
just another truck
I was thinking line degrading, was hoping to get black stuff out when I was bleeding, but yeah, it migh just be the hose. I should get a presure gage and put it on the caliper ( bleed screw) and try that...
Old Jan 31, 2008 | 10:37 AM
mndiesel's Avatar
mndiesel
You might have a caliper that is starting to go.
Old Jan 31, 2008 | 11:49 AM
just another truck
threw money at it Saturday and put the caliper on it, hoping that was the case, but, no ah ah.
Old Jan 31, 2008 | 03:42 PM
SpringerPop's Avatar
SpringerPop
Ya' got to like a guy with a little self-deprecation in him! :-))
Pop
Old Feb 1, 2008 | 06:53 AM
just another truck
Brake update, Went back in last night, tore everything apart, everything apart this time. What I found was them damn little steel clips were rubbing up on the rotor, that was all I found. I pulled them out last night. reinstalled the brakes, no prblem yesterday, or this morning, even with an inch of snow on the ground. I will update in 4 days.......
