Sponsored by: Innova
Sony head unit question
Old Jan 30, 2008 | 01:45 PM
hoxiii's Avatar
hoxiii
Allright, my truck had a Sony XR-CA330 headunit in it when I bought it. It works fine and I have no complaints except for one.
Whenever you turn the truck off it makes this "deedle-dee, deedle-dee, deedle-dee" noise that drives me up the wall.
One of my friends told me it's an alarm to remind you to take your faceplate with you, but i don't and won't.
Is there any way to turn the dang thing off?
Justin
Old Jan 30, 2008 | 01:57 PM
bgalaxy67's Avatar
bgalaxy67
I doubt it. I had an older Sony that did that. I feel your pain
Old Jan 30, 2008 | 02:18 PM
Beerstalker's Avatar
Beerstalker
The Sony unit I put in my dad's truck does the same thing, and I haven't found any way to work around it.
Old Jan 30, 2008 | 02:43 PM
hoxiii's Avatar
hoxiii
Well I asked around a littel more and apparently you can disable it if you bypass the internal amp.
Sounds like I'm just living with the chime or just being sure NOT to get a sony unit if I upgrade to a CD deck.
Justin
Old Jan 30, 2008 | 05:24 PM
ididntdoit99's Avatar
ididntdoit99
Damn thing drove me nuts.... When my son was born he would sleep in the truck all the time. He'd sleep through music, and the sound of my truck. but as soon as i shut it off that little chime would wake him up.
Old Jan 30, 2008 | 08:43 PM
Citypol86's Avatar
Citypol86
My Sony CDX-MP40 manual says, " [SEL] + [6]: BEEP - to turn the beeps on or off." I believe this means press the Select and preset 6 buttons at the same time. It also says that the beep only works when the built-in amp is used. I take this to mean that the beep will work or may be turned off if you use the built-in amp. If the built-in amp is not used, you will not have the beep option.
Hope this helps. The stereo is about three years old. In case you need it, the [SEL] + 3 is the auto-scroll function and the [SEL] + 4 is the manual display function.
Later...
Brewster...
Old Jan 30, 2008 | 09:12 PM
ididntdoit99
Is that the beeps after you shut off the stereo? Or just beeps while you press a button? or both?
Old Jan 30, 2008 | 09:32 PM
Citypol86's Avatar
Citypol86
Its the beeping that sounds after the unit powers off. Its a security reminder [that's what they say anyway].
Later...
Brewster...
Old Jan 30, 2008 | 09:40 PM
ididntdoit99
cool... i'll have to loook at mine and see if it works. Or I could actually look in the book. just something i never bothered to do.
Old Jan 31, 2008 | 07:38 AM
Citypol86's Avatar
Citypol86
Originally Posted by Citypol86
My Sony CDX-MP40 manual says...
O.K. I tried the SEL/6 on the way to work last night and... It does NOT work. It turns off the beep when you press a button on the faceplate. It was a noble attempt... feeble but noble.
Later...
Brewster...
