well i got all paved roads and about 1\2 mile of street befor i hit a main rd so i already have burnout marks up and down it my driveway looks like the burnout box at milan dragway lol
I dont sujest going on FSB forums in your current state...you will get eaten alive. If you go just go to read, dont post. We are downright civil compared to some of the arseholes over there.
And dont even THINK of posting these questions on Pirate....
FSB isn't a bad place to post, ive never had a single problem over there....
For your simplicity just go to broncograveyard and buy item 33809, its a 6inch lift with radius arms and leaf springs. Throw on your 35s and call it good.
Then later on down the road change gears to like a 4:56 "FRONT AND REAR".
When the loss of power finally gets to you, go back to bronco graveyard and buy items 32010c, 32310D, 32319, and 32017. Its 4:56 gears from yukon front and rear, and rebuild kits front and rear with all bearings, shims and seals needed.
The total comes to like $1648.84 Toys arnt cheap
Good Luck
This is what you need. I believe I read that your truck is a 94. If so it has the same drive train as my 89 (same suspention setup). If so your truck is equipped with a dana 44 ttb (twin traction beam). This is a dana 44 differential housed in an axle setup that works almost like a pair of scissors. You should have an 8.8 rear axle. I would not suggest going over 35's with this set up.
Personally I run 36's but that is pushing it. A 6 inch suspention lift would clear 35's fine. I would suggest spending the money now and getting the extended radius arms and full springs in the rear, NO blocks. I would also suggest getting 4.56 gears and remember gears from a straight axle dana 44 will not work. The dana 44 ttb is a reverse rotation ring and pinion.
If you wish to go higher save the money and do a sas (solid axle swap). A dana 44 and 9 in rear should be enught if you do not wheel it hard. I'm guessing you are not that interested in offroad performance. If so step up to a dana 60 front and 10.25 rear or a 60 rear. Reguardless of what you do just make it safe for the rest of us.
I don't know if they'll fit or not, but the solid axle D44 is reverse cut too!
unless its a low pinion, then its std. rotation...
High pinion = reverse cut, or reverse spiral
Low pinion is a standard cut, or standard spiral
The gears still turn the same. "Reverse rotation" is a term that is often confused.
