Offroad & 4x4
highest possible
Old Jan 29, 2008 | 10:17 PM
MBBFord's Avatar
MBBFord
Originally Posted by godblessmud
I cant tell if this is serious or not...
Like should i waste time typing a helpful responce or will i regret it 5 posts from now...
Don't know about you, but I'm already regreating it.
A whole $1,600 for a 40" lift(or 15"... just as unreallistic).
Did you ever hear of Regearing?
Engine performance onther than a K&N filter
Lockers?
Old Jan 29, 2008 | 10:19 PM
4x4 94 f150 302's Avatar
4x4 94 f150 302
if im not mistaken one of the moderators has a 12 or 13 in lift with 35's his looks nice...
Old Jan 29, 2008 | 10:21 PM
4x4 94 f150 302
ya i have extra gears from my mustang i was gonna through in there i have a 5:13 and a 4:56
captain p4's Avatar
captain p4
that is way too much lift for 35s
6inch max on a 94 should cover it.
don't use huge blocks. don't use coil spacers. don't use a body lift.
Old Jan 29, 2008 | 10:23 PM
khadma's Avatar
khadma
Carpenter Local 745
Do you have the fronts too?
Old Jan 29, 2008 | 10:24 PM
godblessmud's Avatar
godblessmud
so you'l be able to regear 50% of your axles, woo-hoo, your right, using 4x4 is overrated anyways, not much use for it in the mall parking lots either!
Old Jan 29, 2008 | 10:25 PM
MBBFord's Avatar
MBBFord
That's what I was thinking. Didn't know mustangs had a front diff.....
Also, don't suggest you run the 5.13s and 4.56 at the same time(t case will bind and expolde).
Old Jan 29, 2008 | 10:27 PM
4x4 94 f150 302
i have a 4:56 from a dana 44 from a 78 4x4 i had that should work right as far as i know i have a dana 44
4x4 94 f150 302
thats y i asked i dont know **** bout lifting trucks just racing cars
Old Jan 29, 2008 | 10:28 PM
captain p4's Avatar
captain p4
the front is a ttb d44 and the rear is an 8.8
you have to run the same gear front and rear with a 4x4 though. can't tell if you're trying to run different gear ratios or not.
Old Jan 29, 2008 | 10:29 PM
godblessmud
Cool 5.13's rear and 4.46's front...cause thats tottaly not gunna explode your differentials (maybe just your d shafts if your lucky...)
Old Jan 29, 2008 | 10:31 PM
4x4 94 f150 302
i just figured the fronts would pull harder j\p no i was gonna run :456's front and rear and kiss my pocket book good buy sense i get like 8 mpg already umm quick stupid question what the hell is ttb or that other one i heard about ????
Old Jan 29, 2008 | 10:35 PM
  #28
quadzjr's Avatar
quadzjr
just another Rockwell looser
most likely the tcase goes....
Old Jan 29, 2008 | 10:40 PM
  #29
4x4 94 f150 302
Originally Posted by DesertStorm
you could run 44's with a 13" lift
i would have a 9in lift the tires would make up the other 4in
Old Jan 29, 2008 | 10:41 PM
  #30
MBBFord's Avatar
MBBFord
Tires don't give lift....
