seriously well the gc then i guess right? id have 13in more of ground clearence ? what is ttb? well what would i need to get 44's under there i have a friend who has sum dick cepeks i could get off him for a grand or one of my cars.
Reason: adding
Try again. With a D44 TTb on 35" tires id estimate your GC at around 7.5" under the differential
35/2=17.5 at center of hubs
17.5-2 (give or take) inches= 15.5 to just clear axle tubes
15.5-5 for the pumkin= 10.5
10.5-3 for TTB= 7.5 if your lucky...like i said in the other thread 35" tires aint that big...
Lift just allows for the bigger tires...a 20" custum 4 link on rockys thats on 36" tires (could you imagine that...) will have the same ground clearence as a stock F350 on 36" tires.
godblessmud, I'm with quad on that one.
The T casue will get put in a serious bind, and more than likely it will be the one to go unless you have a extreamly weak u joint or something and you luck out.
Cutts busted 2 t cases b/c someone told him the D60 had a 4.10 gear ratio and it was only 3.50s and with enough traction the t case would bind and break.
well then captain what would u suggest cuz so far im going with fabtech only because ive heard the best about them and its still within my budget.plus all i said was i found a 6in tha cheapest at rough country....
I don't know anything about ttb trucks, why don't you SEARCH and see what other people have to say? like has been suggested to you about 20 times by now?
I dont sujest going on FSB forums in your current state...you will get eaten alive. If you go just go to read, dont post. We are downright civil compared to some of the arseholes over there.
And dont even THINK of posting these questions on Pirate....
