what's the difference
Old Jan 29, 2008 | 07:31 PM
bronco 71's Avatar
bronco 71
hey all, i've got an 89' f150 4x4. i need to install a new t-case. i found a bw1756 and the one in the truck is a bw1356. are they interchangeable. what's the difference, or is there any. oh ya, my 89 is an auto.
Old Jan 29, 2008 | 07:53 PM
flareside_thunder's Avatar
flareside_thunder
Not sure dude...but the guys over in the Offroad forum could probly help you out with that ?....not tryin to turn you away...just tryin to turn you in the right direction.....good bunch of guys in there.....
JR
Old Jan 29, 2008 | 08:36 PM
bronco 71's Avatar
bronco 71
thanks jr. where do i find this forum. yr.
Old Jan 29, 2008 | 08:43 PM
Skandocious's Avatar
Skandocious
https://www.ford-trucks.com/forums/forum63/
Old Jan 29, 2008 | 08:48 PM
andym's Avatar
andym
I don't know what a 1756 is, but it doesn't sound like it will fit. If you really want the least amount of problems, replace it with whatever's in there now.
Old Jan 29, 2008 | 09:09 PM
bronco 71's Avatar
bronco 71
t-case info borg warner 1756 or borg warner 1356 . 1756 from a 90' f150 auto, 1356 from a 89' f150 auto. are they interchangeable, will it fit.??????
Old Jan 29, 2008 | 09:19 PM
andym's Avatar
andym
I still don't know what a 1756 is, but it was never put in a 1990 F-150.
Old Jan 29, 2008 | 09:37 PM
Fordfr4x4's Avatar
Fordfr4x4
I may be wrong here but I thought the 1756 was bigger all i know is that the 1356 is made with more plastic and uses atf.
Old Jan 29, 2008 | 11:25 PM
95F350XL's Avatar
95F350XL
The 1356 was used in my truck. Maybe thats where ur being confused. F350. I know there are the manual shift tcase, and the electronic shift tcase. Thats prob the number difference. If you go to ebay and type in ur tcase number it will come up and the pages will tell u. My 1356 isnt plastic. There isnt any on it that I can see. No way the gears inside are plastic, or the chain. lol The 1756 was used in the 97-98 F250/F350 from my research. As I need a tcase also.
Old Jan 29, 2008 | 11:32 PM
Skandocious
Not sure where you got your facts about 'more plastic parts'...
My truck has the 1356 (electric shift - it comes in both varieties) and I've dissembled it before. The only plastic parts that I can remember are the small tabs on the shift fork, the oil pump, and part of the clutch assembly (the creme colored plastic fork behind the spring in the picture). Here's pics of mine:
Closeup of the plastic shift fork tabs that sometimes wear out:
These plastic parts are not under heavy stress so there's no problem with them being there, they wont break. The only ones that can be an issue are the plastic shift fork tabs. But with proper usage, lubrication, and maintanence they shouldn't create a problem. Cracked mine open at 100k miles and the guts of the ENTIRE case looked brand spankin new, as you can see.
Old Jan 29, 2008 | 11:36 PM
Skandocious
As for the 1756 I have no idea... I'm not seeing any records of it on this page:
http://www.drivetrain.com/transfercaseapp.html#F100%20150%20Series%20PICKUP
In fact, I'm not seeing ANY Borg Warner cases there with models that start with 17__ at all. Not to say they dont exist but damn thats a pretty big list to not include any 17__ cases
Old Jan 30, 2008 | 03:54 PM
flareside_thunder
Me neither Chris.....
JR
Old Jan 30, 2008 | 04:48 PM
Fordfr4x4's Avatar
Fordfr4x4
My apoligizes I should have worded that a little cleaner, that t-case was described to me as having plastic components, not that they were cheaper but be weary of them, in other words when that shift **** sticks dont go yanking the crap out of it, i personally have never had a problem with mine or know of ne1 that has had a problem actually related to plastic parts in the case.
Old Jan 30, 2008 | 04:51 PM
Fordfr4x4's Avatar
Fordfr4x4
Actually I just looked at my records as well and only have the 1345 and the 1356
Old Jan 31, 2008 | 10:20 AM
tfowler306's Avatar
tfowler306
maybee the tag on that 1756 is just damaged or so dirty he cant read it accuratly?
