Offroad & 4x4
FRONT D44 Troubleshooting
Old Jan 29, 2008 | 05:38 PM
lmp5115's Avatar
lmp5115
I own a 1979 Ford f250 and i recently broke out my axle shafts/ I replaced them using chromoly axles and now it seems my steering radius is completely shot. My u-joints try to bind before even maxing out the steering in either direction.
What may be the problem?
Old Jan 29, 2008 | 06:10 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
operator error?
i dont see how you could mess up installing a ujoint
Old Jan 29, 2008 | 06:22 PM
78250crewcab4x4's Avatar
78250crewcab4x4
What brand of shafts?
Old Jan 29, 2008 | 06:26 PM
projectnitemare's Avatar
projectnitemare
I wouldn't see the universal being the problem but maybe the yoke. If whoever made the shafts decided to beef up that area you can run into some binding between the yokes. That would be something you would want to check, usually tends to be an issue with driveshafts rather than axle shafts. If you have a stock shaft left over to make a compairison would be helpful. If the new shaft binds before the stocker call the manufacturer to see if it can be corrected though them or if you grind them out will they still provide any warranty.
Matt
Old Jan 29, 2008 | 06:35 PM
75F350's Avatar
75F350
Are the new joints any larger than the old ones? Which shafts did you go with?
Did you measure the differences between the old shafts and the new ones?
Should be easy to find the diffrences between the shafts, and determine where you have the limitation.
Old Jan 29, 2008 | 07:27 PM
lmp5115's Avatar
lmp5115
well i ordered these shafts from Bronco Graveyard, came with the recommended u-joints and the shafts match in length and spline count to the stock. this really got me stumped.
Old Jan 29, 2008 | 07:33 PM
quadzjr's Avatar
quadzjr
they carry multiple brands of shafts....but i got the yukon ones, and put them in my bronco and my steering wan't affected, if anything its better b/c of the bigger 760x joints...
elkarcher1716
21
Mar 18, 2013 08:23 PM
73cntry
Aug 11, 2009 05:52 AM
fingarr
Sep 27, 2007 09:25 PM
Paul Gillmouth
Nov 27, 1999 04:41 AM
