Sponsored by: Real Truck
Rear end chatter / shudder ??
Old Jan 29, 2008 | 11:57 AM
rfish84's Avatar
rfish84
Hi guys, hopefully someone can provide me some insight on what to do for this.
I bought my 2002 F350 Lariat Supercab long bed back in the spring time, with 53,000 miles on it. absoultely beautiful virgin truck. Runs perfect. The only questionable thing was that sometimes when taking a hard turn from a dead stop, i would feel this shuddering / chatteing from the rear. it is enough to really shake the truck when it happens.
I showed it to the dealer where i bought the truck, and he said it must be the clutches? in the rear end grabbing too much when making the turns from a stop. He took the truck in and serviced the rear diff, including some additive that makes them grab a little less? BTW, its a 3.73 rear.
It seemed to help some, but never went away 100%, and of course now my warranty through the dealer is over.
I was really noticing it yesterday when driving. Every time i took a right turn from stopped at a light, i really felt the chatter or shudder.
What do you guys make of this?
thanks in advance,
Ryan
Old Jan 29, 2008 | 12:01 PM
MisterCMK's Avatar
MisterCMK
Sounds like the clutches are worn out. You'll have to replace them.
Old Jan 29, 2008 | 12:14 PM
dkf's Avatar
dkf
You could try putting in more limited slip additive(Friction Modifier), that might help.
If the rear diff is shot I wouldn't bother fixing the stock Ford limited slip, as they pretty much suck. I know I have one in my truck.
I'd look into an aftermarket posi like the Truetrac or an Elocker. They will work much better than the Ford limited slip.
Old Jan 29, 2008 | 12:20 PM
MisterCMK's Avatar
MisterCMK
Hmm, that truetrac looks like a nice unit. I'm tempted to just pick one of those up rather than rebuild the trac-lok on the Expedition.
Old Jan 29, 2008 | 12:31 PM
1996pwrstrk's Avatar
1996pwrstrk
I would go with a little more friction modifier my dad has a 02 with 134,000 miles no problems and a friend has one with almost 200,000 miles other than service has done nothing to it. I have a Dana 80 in my dually and run Royal Purple with no modifier (none is needed ) and my LS works good with no noise.
Old Jan 29, 2008 | 12:36 PM
rfish84's Avatar
rfish84
I highly doubt the rear end is worn out, the truck was a one owner who was an older guy who passed away and really didnt use the truck. Hence the 5 year old truck with 53k on it.
So just more friction modifier you suggest? What exactly is causing this? I've had a few other trucks includig an older F350 and never felt this shudder before
Old Jan 29, 2008 | 12:42 PM
1996pwrstrk
The clutches are grabbing not sliding smoothly the modifier is super slippery stuff alittle goes a long way . I'm with you that rear diff. has many more miles in it. I honestly would just change it . Put Royal Purple in and forget it .
Old Jan 29, 2008 | 01:04 PM
rbaker6336's Avatar
rbaker6336
first need to make sure it has synthetic oil in it if so probly needs a little more modifier
you didn't say if it was DRW or SRW,the DRW tends to chatter worse
as far a wore out clutches I would be more worried if it didn't chatter some
my dually has chattered over 100k miles,just something I live with
BTW when it didn't chatter the clutches were shot
Old Jan 29, 2008 | 01:16 PM
rfish84's Avatar
rfish84
Its a single rear wheel
Old Jan 29, 2008 | 02:56 PM
rugermack's Avatar
rugermack
I put Royal Purple in mine(no additive), 147k still works as good as it can. I don't think a little old man would wear it out in 53k.
Old Jun 12, 2008 | 08:48 PM
Rattle&Roll's Avatar
Rattle&Roll
I tow a 12,500 lb 5er and get the chatter when I take off from a stop, or if I am "spirited" when unloaded. Worse when turning and take off. At 60K miles took it to jiffy and had fluid changed and a bottle of Ford limited slip conditioner added at the same time. Went to a parking lot and drove a right hand tight circle about 10 times and then left about 10 times (slowly). Repeated the process in reverse. The chatter was gone. About 15 k since then and I am getting it again, so my plan is to just add some more conditioner. Will let you know...
mjkorcek
Mar 24, 2016 04:31 PM
Keeseter CO
6.7L Power Stroke Diesel
Oct 8, 2013 09:17 PM
abubba1
6.4L Power Stroke Diesel
Sep 27, 2013 06:12 AM
banditsdaddy
Mar 29, 2008 11:17 AM
Don Caldwell
2004 - 2008 F150
Dec 18, 2005 06:39 PM
