Problem with E4OD Trans.
Old Jan 29, 2008 | 08:29 AM
tailgater2000's Avatar
tailgater2000
I have a 1996 F250 4x4 used primarily for pulling a landscaping trailer and snowplowing. Driving around without the plow the transmission is fine, even on lengthy drives. However once the extra demand of plowing snow is applied, the transmission pukes tranny fluid at the bottom of the bellhousing. Heat and pressure build up is the problem. A blocked vent tube could be the problem, but if the fluid is not being purged through the vent tube, where is it coming from? and why does it reseal itself when cooler-and not plowing snow?
Thanks
Old Jan 29, 2008 | 05:43 PM
mhg's Avatar
mhg
they will puke at the weakest place
I have had one that sent it out the dip stick tube
get a bigger cooler and add it to the front of the radiator
on my van I put a second factory cooler in line
picked it up for 10.00 at a u pull it
Old Jan 29, 2008 | 05:47 PM
quicklook2's Avatar
quicklook2
when was it last serviced?
a complete draining of fluid, new filter and adding a cooler is where you should start.
a trans. temp gauge would be a good idea.
a deeper pan would be a good idea.
do not wait too long or it will puke once too many times and let you down.
Old Jan 29, 2008 | 06:43 PM
jr32560's Avatar
jr32560
mhg and quicklook2 are on the money on this one -friend had one doing the same thing-larger cooler and trans service cured the problem-also use low range when plowing-takes a lot of bind off the auto trans and puts it on the transfer case
