2007 F150 Plug removal
Old Jan 29, 2008 | 08:41 AM
mrpositraction's Avatar
mrpositraction
Hello everyone. I have the TSB and read most (there is a lot of them) threads on plug removal. My question is a little different. I was wondering if anyone has changed plugs on a newer truck yet (2007 preferably) and encountered any troubles. I have the TSB (<--for search/reference) but just wondering if anyone had broken plugs in a newer motor. Right now I have 12600 miles on my ride and will most likely do the S/C install before 15,000. I also have the "special" ford socket on order for removing the plugs.
Thanks,
Greg
Old Jan 29, 2008 | 09:12 AM
Ulf's Avatar
Ulf
If you have the old style cylinder heads on your truck you will have problems with the spark plugs breaking........
Ford came out with a new style head in October 2007 I think, please don't quote me on that...
Old Jan 29, 2008 | 09:18 AM
MBBFord's Avatar
MBBFord
Like Ulf said, you have the old design heads, and they were redesigned in about 10/07, and they mostly went in the 08 model trucks.
You don't have much carbon build up or rust with such low miles, and if you followed the TSB and took your time, you could do it successfully.
I saw a dealer break a plug off of a 06 with about 30k miles on it.......
Old Jan 29, 2008 | 09:25 AM
MBBFord's Avatar
MBBFord
I highly suggest you use the Kroil just as a precaution.
You could put your plugs back in(don't need to replace them, b/c you'd just be putting the same style back in), but just put some Nickel anti seize on the ground electrode, and possibly the threads if you wanted.
Old Jan 29, 2008 | 09:47 AM
mrpositraction
The stock plugs are equivalent to the HTO's that are supplied with the Roush kit?
Old Jan 29, 2008 | 10:04 AM
MBBFord's Avatar
MBBFord
No comment.....
I don't see how they could use any other type of plug that wouldn't break b/c of the cra*py head design!, but I don't know.........
Old Jan 29, 2008 | 10:15 AM
mrpositraction
No comment.....
So the HTO's are prone to breaking also? That is great!
Old Jan 29, 2008 | 01:31 PM
MBBFord's Avatar
MBBFord
I didn't say that... I haven't seen one of their plugs, but I couldn't imagin another way to make a plug with that stupid head design.....
Old Jan 29, 2008 | 02:32 PM
mrpositraction
So what did you mean then? What would you suggest?
Old Jan 29, 2008 | 03:11 PM
MBBFord's Avatar
MBBFord
Like I said, with such low miles, you would have a high success rate of taking the plugs out without breaking them, and putting some nickle anti seize on the ground sheild, sticking them back in, and waiting to do it again or there might be a fix latter on....? The nickle anti sieze will protect from the sheild seizing into the head and breaking off latter, b/c it won't let carbon build up on it.
It'd be a good idea to put the nickle anti seize on now rather than waiting untill you get 50k miles if you plan to do it at all.
Old Jan 29, 2008 | 04:16 PM
WilZol's Avatar
WilZol
I bought an 08 in December, the 29th to be exact. How can I tell for sure which heads I have on my 5.4? Is there a way to determine this and if so how?
Old Jan 29, 2008 | 04:42 PM
MBBFord's Avatar
MBBFord
All 08s are supposed to have the redisigned heads, and I'm not sure, but I hear there's a chance some 07s have them to.
The design change was in or around 10/07, and I'd put money on that.
Look at the build date on the info tag on the drivers door jam.
Old Jan 29, 2008 | 07:06 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
On the drivers side valve cover is a decal with the engine build date.
Old Jan 29, 2008 | 07:24 PM
mrpositraction
I am supercharging, I need one range colder.
Pilgrim
45
Feb 1, 2018 08:22 AM
No-Tyme
2004 - 2008 F150
Nov 20, 2008 08:21 PM
berry1234
19
Apr 7, 2008 03:09 PM
rprhyno
2004 - 2008 F150
23
May 30, 2007 06:42 PM
GlennJ
2004 - 2008 F150
25
Jan 15, 2007 05:39 PM
