Sponsored by: Real Truck
FX4 ride compare?
Old Jan 29, 2008 | 02:46 AM
boatflounder's Avatar
boatflounder
FX4 ride compare?
I am new her and am looking to get an 08 250 in the next couple months, will be a supercab V10, probably long bed but still not entirely sure on bed length. I really prefer the looks of the FX4 package but am a little concerned about how it rides compared to a lariat or xlt with the offroad package. I do most of my driving onroad but definitely want the capabality of 4X4, any input is appreciated.
Old Jan 29, 2008 | 03:50 AM
ryaneverk2's Avatar
ryaneverk2
Welcome to FTE.
The Fx4 package is just a 4x4 truck, plus skid plates (under the transfer case and fuel tank), different shocks, and the nifty Fx4 sticker.
Some folks just get 4x4 and add skid plates, doing without the sticker and shocks, and saving a bit of dough.
4x4 will definitely ride a bit rougher than 4x2, and will get worse mileage due to increased drag. Nice to have it when you need it, though, and ride tends to improve if you add weight (hauling stuff in the bed, for example... my truck never rides smoother than when the bed is fully loaded).
Old Jan 29, 2008 | 04:00 AM
boatflounder
Thanks Ryan,
Iguess I want really clear, will definitely be going 4X4, just want to know how different those FX4 shocks are?
Old Jan 29, 2008 | 04:57 AM
ryaneverk2's Avatar
ryaneverk2
I'm honestly not 100% sure. Don't know if the 08s are different, but it used to be they were Rancho shocks. The rub is that some folks have said they're not genuine Rancho shocks, but some other shocks with Rancho stickers on them. Even if that's not accurate, it does seem to be agreed that they're not the best aftermarket shocks available, and that you're probably better off just going with 4x4 and adding the skid plate package, and then getting some aftermarket shocks on your own.
If you do a search on Rancho, "Fx4 package", things like that, should be plenty of reading available that will go into more detail.
Old Jan 29, 2008 | 07:16 AM
ffadragon's Avatar
ffadragon
There is no difference in ride. It is more about how it looks with a few things like stated above. You can do what 75% of other people on this formum have done if you don't like the shocks that are on it when you get it and that is swap them out for some good ones. I have Bilsteins like so many others on here. They are by far the best upgrade I have ever made on a truck. You can get a set of 4 for about $250 - $275, and they are well worth it.
Old Jan 29, 2008 | 07:38 AM
mastercaster's Avatar
mastercaster
those "Rancho" shocks are just rebranded ford shocks (read crap). there will be no ride difference unless you change the suspensioin by adding the camper package, heavy service springs, etc. i changed my "Rancho" shocks on my fx4 at about 25k-30k, and went to the Bilsteins. that was a HUGE improvement. i would have done that the very day i brought the truck home if i'd of known the difference it would make! do a search on the shocks. there are plenty of threads about how crappy the stock rancho's are.
Old Jan 29, 2008 | 07:40 AM
snelldawg's Avatar
snelldawg
This question has come up many times...the FX4 shocks are 'Rancho branded' which means that they are factory shocks that are painted to look like Rancho's. A lot of guys on this forum have upgraded their shocks at some point because the factory shocks aren't great.
I like the idea of skipping the FX4 package, upgrading to Bilsteins and then adding the skid plates if necessary.
Old Jan 29, 2008 | 08:16 AM
Deluxe05's Avatar
Deluxe05
Don't get hung up on the FX4 option package available on the "earlier" Super Duties with the 2008+ FX4 trim level.
The option package (2003-07 ?) required 4x4, AT tires, and a limited-slip axle. And, it provided transfer case and fuel tank skid plates, Rancho branded shocks, and the "FX4" decals.
The new generation of Super Duties (2008+) offers an FX4 trim level which is a complete interior & exterior revamp that fits between the XLT & Lariat trim levels. Look at this semi-recent thread for a full run-down on what is included in the FX4 trim package: https://www.ford-trucks.com/forums/6...lt-or-fx4.html
As to the original poster, the only difference that may have any impact on ride quality is still the Rancho-branded shocks. This is still a pretty minor difference; a Super Duty is going to ride like any other heavy duty truck. Some folks have reported that swapping out the Rancho-branded shocks for something like Bilsteins can help ride quality a bit. But, if you really like the FX4's overall interior/exterior appearance, I would not look at other trim levels just because of the shocks. They are, after all, easy enough to swap out.
Old Jan 29, 2008 | 09:45 AM
Mmaxed's Avatar
Mmaxed
You don't want to order any packages that include heavier springs. The stabilizer package has heavier front springs and rides stiffer that without. I drove both while I was shopping.
Old Jan 29, 2008 | 10:19 AM
PERFORMANCE RED's Avatar
PERFORMANCE RED
I never understood the reason to have skid plates on a truck that sits 2+ feet off the ground. I had skid plate on my Bronco because it was lower to the ground and I think they were used one time. I don't know to many people rock crawling with a SD, I know some do but not enough that people need skid plates on a superduty IMO.
Old Jan 29, 2008 | 10:23 AM
ffadragon's Avatar
ffadragon
If you do any driving in the woods it comes in very handy. I am not worried about rocks, it is sticks and limbs from trees. That is when a skid plate can come in real handy, like for most hunters.
Old Jan 29, 2008 | 10:34 AM
centexKR's Avatar
centexKR
On the Bilstein shocks. Do they offer just a smoother ride or do they help with the tracking too. Its seems the 250 wanders more
on the hwy than a 4x4 150. Its in alignment, not pulling to
one side or the other.
Old Jan 29, 2008 | 10:56 AM
rugermack's Avatar
rugermack
Well, maybe in Mn. you don't need them. I was out scouting for Javelina this past Sunday and put a few scratches in my skid plates, and I have a 6.5 lift and 35" tires. Here in Arizona there are alot of rocks. Glad the skid plates were there. One other thing they protect the truck from is road debri., imagine a trucker loosing a retread, skid palte would save you there too. Plus, they add some rigity to the frame, since they go from rail to rail. My hitch helps out a lot too, it protects the rear bumper. I'll bet my hitch has saved my bumper atleast 50 times.
Old Jan 29, 2008 | 11:09 AM
PERFORMANCE RED
My truck is a farm tool. It see's a good amount of work. I guess I would go around or move the limbs and trees first. If a limb or a tree can hurt my transfer case I am sure it won't be good on my tires either.
As stated in my orginial post you can see that some people, like you, would have a use for them. I still believe that most people don't need them.
Old Jan 29, 2008 | 03:22 PM
boatflounder
Thanks for the insite guys.
definitely do prefer the appearance of the fx4 package so may be back in a few months asking how to change shocks if they do cause a problem.
