I occassionaly hear a very distinct "CLUNK!" in the front end of my truck.
Sounds mechanical, like a bad ball-joint or something.
It happens most frequently when taking off from a stop where I have to turn.
I've gone underneth to ensure everything is good and snug, as well as lubed.
Nothing "jumps-out" as suspect.
For the weird part.... I usually does it when it's wet.... either during or after rain.
Ideas?
The vehicle is a 2003 F-250 4X4 PSD Supercrew, short wheel base.
I've changed ball joints on both sides of my 04. Mine would clunk some also. Jack the front end up and try to wiggle your tire up and down. if it moves your ball joints are bad
Thanks!
Are they pretty easy to change?
Or is this a job that requires speciality tools (bearing presses and what-not)?
I also read that sway bar bushings were known to cause a similar symptom..... I just visually checked them, nothing out of the ordinary visible.
Relatively easy to do, just a bit of banging and you'll need to rent a ball joint press to make it go a lot quicker. ball joint press just looks like a c clamp that has an open end. I did mine myself last year because I had a clunk as well, turned out it was my sway bar end links in the end, even though on a visual inspection of them they appeared to be fine
you can get a ball joint press loaner at autozone. The hardest part is removing the unit bearing. I found that a air chissel helped quite a bit to split the bearing from the steering knuckle. My sway bar links have been replaced to
i replaced my ball joints with MOOG brand they are greaseable.the best price i found was ROCKAUTO.com all 4 were cheaper than just the lowers at the auto parts store.
Mine were bad.But i still have a clunk when turning the wheel all the way to the left or right and hit the pedal.I have nearrowed the noise down to my leave springs.If you turn the wheel hard while stopped and hit the pedal say turned to the right youll kind of push threw the front end and smake the springs together.I did this with me laying on the ground and my brother in the truck.
Cuz it was killing me not knowing WTF it was.
We drive this truck across the country racing.we didnt want a falure on the side of the road in the middle of nowhere if we can help it.105,000 miles and hasent happen yet. knock on wood.Heading to HOUMA,LA next month
Another thing to check is your leaf spring bushings.
I had a clunk, changed the swaybar bushings, but the clunk didn't go away.
I finally realized the the rear bushings on the front leaf springs (superlift) were shot. The springs were sliding side to side about a quarter inch and that is what was clunking.
The bushing failure was caused by the track bar drop bracket coming loose. The bolts sheared off at the frame so all the lateral forces were carried by the leafsprings, instead of the track bar.
You said it happens when it is raining or after raining. Does it happen when you are stopped also? I think maybe your defrost is on and the pump is engaging. Pop the hood with the defrost or air on (I don't know were you live) and listen from the passenger side (uptop) Hope it is that simple. good luck
I have a loud "clunk" shortly after initial starting of my truck (within seconds of starting). Any ideas?
Also, I'm new to diesels and have only had mine since last May. Mine takes forever to warm up. It's very loud until it warms up. After warm, it runs pretty quiet. Is this normal?
Thanks for any info out there.
"06 F-350 Lariat CC Longbed
That clunk, which probably sounds like it is coming from under the dash near your feet, is the hvac box closing.
And yes, it is normal for them to take longer than a gas engine to warm up and be loud and clanky until they do.
i had the same clunk and I had someone quickly turn the wheel back and forth while I looked under the front end and the track bar bushing was bad. the side that mounts to the frame. It moved a good half an inch. I ended up having to replace the whole track bar with another stock from ford as there isnt an aftermarket one out there yet for it as it has a ball joint on one end.
