Random "No Start"
Old Feb 19, 2008 | 07:18 AM
F350-6's Avatar
F350-6
Do you still get the 1212 code?
DC15 CONTINUOUS DIAGNOSTIC TROUBLE CODE (DTC) P1212
Note: This code may set after a high-pressure oil system repair (i.e., injector change). Drive vehicle to clear air from system after repair, and clear code.
Continuous DTC P1212 indicates that there was no ICP detected during crank (long crank time).
Possible causes:
empty/low oil reservoir at crank
low engine oil level or incorrect viscosity
IPR circuit fault
damaged low-pressure oil pump
damaged IPR valve
damaged ICP sensor
damaged high-pressure oil pump
Check engine oil level.
Perform KOEO On-Demand Self Test to verify ICP/IPR circuit faults are not present at this time.
Also check to make sure you don't have any chaffed wires. Next time you get the no start, try wiggling the wiring harnesses under the hood, especially the wires to the ICP. Chaffed wires can cause a PCM short to ground which results in a no start that seems to miraculously cures itself.
I had one of those on the main engine wiring harness, but the glow plug light & water in fuel light acted funny.
Old Apr 29, 2008 | 10:34 AM
mkmathis76's Avatar
mkmathis76
So what was the final issue??? I have the same problem now...UGGHHHH
Old Apr 29, 2008 | 10:59 AM
Trailblazed's Avatar
Trailblazed
It was a Bad ICP sensor. Even though the sensor looked good, that was the problem. It was just a very random no start. Most times it would start, others not.
Old Apr 29, 2008 | 11:02 AM
mkmathis76's Avatar
mkmathis76
With mine it will start and drive for "awhile" then just turn off... 30 mins or so later it will restart. codes were 381,1209,1212,340,1211,670... 3 of them are ICP... How hard and expensive was that project ????
Thanks again!
Old Apr 29, 2008 | 11:57 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I have to wonder why you never posted the fact that you solved the problem. That's how we learn here, plus it's nice to know the results. Come in here and ask a question, fix it and not let us know. That's kind of like a "slam bam thank you ma'am".
Old Sep 25, 2011 | 04:03 PM
95FordTruck02's Avatar
95FordTruck02
Alright... looks like I am having a problem very similar to the OP. Since his explanation in the first post says it all, i figured i would bring back this thread rather than start a new one.
Same starting problems.. very random, and usually the only solution for it to start back is giving it a few minutes. I have waited anywhere from 5 mins to 30 minutes for it to successfully start back up. It seems like the more i try to start it the longer it takes.
Unlike the OP, after replacing my ICP and pigtail the problem did not go away. I was really hoping that would do the trick, but no such luck. Additionally, I had taken it to the dealer but they couldn't reproduce the problem and blamed it on my chip being loose. They removed the chip, but it is still having the issue. no luck there.
My question.. since it seems to start back up after sitting for a little while could this be an issue related to the alarm system? I have a ford system, no remote start. Or does this sound more like an issue with the oil pressure system? are there any other sensors to look for besides the ICP? Dealer said it was not throwing any codes.
Also, I dont believe it is the CPS as I have replaced it before and I have no problems once the truck is running. Runs like a champ.
Old Sep 28, 2011 | 02:07 PM
95FordTruck02
Bump... Any thoughts?
brian42
Feb 1, 2017 04:44 PM
Dr. Johnson
102
Oct 13, 2016 03:45 PM
acf6
Feb 3, 2016 11:33 AM
RazorSVT
6.4L Power Stroke Diesel
Nov 23, 2011 10:44 AM
Pocket
57
Sep 22, 2010 11:38 AM
