engine block heater plug
Old Jan 28, 2008 | 07:24 PM
powerstroke1869's Avatar
powerstroke1869
well i had a problem with my engine block heater not working i found my problem was that one of my wires connecting to the plug was broke off so i spliced a new extension cord and cut it to the length i wanted... the stock cord was a little short i made it hang out a little bit. hopefully it worked im gunna check it a little later and see if the cord is warm so im hoping i did everything right
Old Jan 28, 2008 | 07:28 PM
jhand124's Avatar
jhand124
Put your ear by the driverside tire you should hear it sizzle
Old Jan 28, 2008 | 07:35 PM
zx250's Avatar
zx250
Of the next Riffraff East
Might want to check this out:
on this thread https://www.ford-trucks.com/forums/6...is-happen.html . It will make you want to make sure everything is right.
Old Jan 28, 2008 | 07:38 PM
powerstroke1869
now how in the world did that happen that just made me a little nervous im thinking bout using a gfci just in case
Old Jan 28, 2008 | 07:44 PM
zx250's Avatar
zx250
Yep, and that happened with the OEM cord that ford installed. Don't want to scare you but don't want you to burn your truck up either. I would us a GFCI for sure.
Old Jan 28, 2008 | 07:46 PM
powerstroke1869
yea i agree.. this noise your suppose to hear is it that distinct its damn windy here in wisconsin and i cant hear nuttin that good should i still be able to hear it??? thanks for the help fellas
jhand124's Avatar
jhand124
Your outlets in garage or outside should be gfci on a newish house. If not I would definitly add one
Old Jan 28, 2008 | 07:50 PM
powerstroke1869
how hard is it to replace the whole deal and get a new plug and such... do i need to remove nething
Old Jan 28, 2008 | 07:57 PM
zx250's Avatar
zx250
I think you can get the OEM cord from the dealer for around $50.00 or so.
Old Jan 28, 2008 | 08:01 PM
powerstroke1869
hmm i was lookin on ebay and they are selling it for the same price... at that price i can just go to the dealership and have it right away... the heater element is right above the oil filter and runs to the front of the truck?
Old Jan 28, 2008 | 08:03 PM
huntke's Avatar
huntke
I went to international and got the whole heater.....cord and all for $32. They sell just the cord but were out and I needed one bad.....didnt ask how much.
Old Jan 28, 2008 | 08:17 PM
powerstroke1869
hmm well after searching a little bit i mite put that LED light on my dash and connect it to my gpr and just use that instead of pluggin it in seems simple enuf to do and very cheap parts are only like 5 buck total at RS gunna pick that up tomorrow and do it... this will also save money on the electric bill
Old Jan 28, 2008 | 08:20 PM
ford1183's Avatar
ford1183
Thats my truck in that pic after looking at the wire it was broke to and no gfci new cord at dealership $60.00 I would defently get a new one.
Old Jan 28, 2008 | 08:22 PM
ford1183's Avatar
ford1183
Forgot to tell you there was one on ebay NEW last time i looked $26.00 $10.00 shipping
Old Jan 28, 2008 | 08:29 PM
zx250's Avatar
zx250
There are a great many that plugs thier trucks up every night with no problems. I didn't want to scare you into not using your block heater, only make sure your wiring is up to par. I don't like seeing post like Clifs, He was lucky it didn't do more damage than it did. A gfci may have helped. A good maintained cord should not cause any issues and help in cold weather. Glow plugs will do the job about starting the truck, but the block heater will give you a warm engine and warm cab sooner. So, If you need it, don't be afraid to use it. That's what it is there for.
