A "Universal" Vacuum diagram.
Yellow has a turn on of 150 degrees, so the charcoal canister won't purge until then.
The red PVS is for the overheat protection (gives the dizzy full vacuum when over 245 degrees).
The small valve inline, from what I can see, delays vacuum advance from turning on immediately, which in theory should be helpful... I'm not 100% on this.
I also added in the air cleaner vacuum setup. I'm not sure what the 'cold weather' switch in that circuit is for, but I am in MA, so I suppose I need it, lol.
Any input this this? Should I research this and go further?
Again this isn't for any 'specific engine' or 'calibration'. Just for the guy with say, a custom engine swap, and wants to keep the charcoal box going, but doesnt have an EGR or anything like that. I figured this was the best forum to show what I've been working on in photoshop.
http://i9.photobucket.com/albums/a72...perdiagram.jpg
The air cleaner vacuum controls look correct. To answer your question, the snorkel in the factory air cleaner houses a small door operated by a vacuum motor. A bimetallic temperature switch in the air cleaner routes vacuum to this door so that it can close for cold under-hood temperatures, so that the air going in to the engine is taken from warm air wafted from the exhaust manifold, through a heat duct. This prevents carb icing. I live in Texas and get carb icing if it's wet out and below 40 or so.
Lastly, no PVS is necessary for a vacuum advance. It needs vacuum at all times. Some setups use manifold vacuum and some setups use ported vacuum for the vacuum advance. It depends on what the initial timing mark specification is.
I can't offer advice on the charcoal canister because the only vehicle I've had that used the purge valve is my truck, and the canister is long gone on that. My other vehicles use the early canister design without a purge valve.
- My question on the air cleaner circuit was the "Cold weather valve".. which is in addition to the little bi-metallic sensor. Seems some Ford setups had this, some didn't.. I'm curious what it is/does. (labeld ACL CWM)
The whole PVS system isn't 'necessary' I know. A really plain jane setup is to just go right ro ported vacuum.. However, this setup uses red PVS is for the overheat protection (gives the dizzy full vacuum when over 245 degrees... so that engine idle speed increases... circulating more coolant). This layout too was ripped from another truck.
This whole thing came about because I wanted a 100% functional evap with a Holley/Edelbrock, then I figured hmm what else might be useful
