Another Valvetrain Problem
Old Nov 17, 2001 | 09:40 PM
chesid24's Avatar
chesid24
This is for all you old Ford guys. BIG PROBLEM Okay here's the deal, it's a 1969 429 block. With reconditioned 1972 heads. Both non-adjustable but different styles. Original 1969 heads had positive stop studs, 1972 heads have pedastal mount rocker arms. With these heads i used the pedestal mount rocker arms and the pushrods that came with those rocker arms. Here's the problem, rocker arms are too tight and make a lot of noise, due to coil bind i believe. As near as i can tell i need shorter pushrods. Can anybody tell me if this is the problem and where i can get parts? One more item i should bring to mention, in 1972 ford raised the deck height of the block .022" to lower compression due to emissions, which is where i get the idea i need shorter push rods. Any help would be greatly appreciated. 1969 heads = C8VE-E 1972 Heads = D3VE A2A.
Thanks, Randy
1973 F100 4" Skyjacker
1969 Galaxie 500, 429 hopefully running soon
Old Nov 17, 2001 | 09:50 PM
bountyhunter's Avatar
bountyhunter
HUH first of all if you raised the deck, you would move
the head away from the lifter so you would need longer
pushrods. How would you raise the deck? gaskets?? Maybe
the noise is that the pushrods are to short, can you
turn the pushrod with your fingers when everything is
tight and both valves are closed? good luck
Old Nov 17, 2001 | 10:04 PM
chesid24's Avatar
chesid24
Ok, I didn't raise the deck height. All i'm saying is that i have a 1969 block which has a lower deck height than a 1972 block. With these heads that i'm using it would mean that the rocker arm is too close to the lifter, as far as i can tell. The rocker arm is tight, too tight, i believe the spring is binding.
Thanks Randy
Old Nov 18, 2001 | 12:09 AM
Mil1ion's Avatar
Mil1ion
[updated:LAST EDITED ON 18-Nov-01 AT 01:21 AM (EST)]HTH
It's from the Speed Pro Parts catalogue.
The application shown is for 429's from 68-73
and for 460's from 68-78
Pleas Excuse my pen marks .
They are prices here in Canada
Dennis
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Nov 18, 2001 | 10:29 AM
Chuck P.'s Avatar
Chuck P.
I really think you should try to get hold of a pushrod length checker, it's just like a pushrod that can be adjusted by threading in or out. This will give you exactly what length you need. Only way to adjust other than pushrod is to shim underneath the pedestal, I think crane makes these in several different thicknesses but wouldn't use these if you need a lot. But .025 or so may be enough to get you going and wouldn't be excessive. I think you may be "bottoming" the lifters and maybe even holding the valve open when it's suppose to be closed as well as binding when trying to fully lift.
Old Nov 20, 2001 | 11:55 PM
bonzi88's Avatar
bonzi88
Post Another Valvetrain Problem
I plan on bolting on a set of 1977 heads onto a 1970 motor.Crane cams
makes a guideplate conversion kit which u can bolt on 7/16 studs & guideplates on to a pedestall style head with out machine work.Then get a set of Polylocks or Kool nuts to make everything adjustable like a chev..
Jegs part # for 3/8's pushrods is 270-35655-16......$79.99
Crane has a kit for 5/16 pushrods too which is a little cheaper.Go to Crane cams web site & dig a little....you'll find them.
Old Nov 21, 2001 | 08:32 AM
bigsnag's Avatar
bigsnag
What cam are you running? What springs do you have? Stock? Coil bind usually comes from a cam that is too big for the springs. If you have the right springs for the right cam and are actually having coil bind, then your biggest problem is that fact that your valves are being held open.
Old Nov 21, 2001 | 09:46 AM
wtroger's Avatar
wtroger
Ford has a collasped lifter clearance procedure outlined in there shop manuals. I would advise looking up that procedure and using it. I just looked at it last night because we are building a 460 but I do not have it in front of me but you collaspe the lifter by prying back on the rocker and then read the clearance between the tip of the rocker and the valve stem. if it is to tight you use a shorter push rod if it to loose a longer push rod.
Old Nov 22, 2001 | 05:27 PM
georgedavila's Avatar
georgedavila
Chuck P's right when he says get a pushrod length checker. You've involved a lot of factors, including lowering the seats if you did a valve job. Do it right and it'll be one less thing to worry about.
Old Nov 25, 2001 | 10:55 PM
chesid24's Avatar
chesid24
Well, i got it figured out thanks to Chuck P. Shorter pushrods and a Pedastal shim kit did the trick. Thanks for all the help. Oh, and don't buy the cheap chrome valve covers off Ebay if you're using anything bigger than a stock cam. The rocker arms don't clear. Thanks a lot.
Randy Neset
1973 F100 4" Lift
1969 Galaxie 500 429 Built
Old Nov 26, 2001 | 01:10 PM
ryanstruck's Avatar
ryanstruck
sandrew1202
13
Aug 2, 2017 12:57 PM
akblackfoot
Jun 23, 2017 09:47 AM
davidmoss1992
Apr 12, 2012 09:41 PM
fordguy76
Oct 1, 2011 09:42 PM
1972 Ford Thunderbird 429 V8
13
Apr 13, 2003 09:07 PM
