motor swap
Old Jan 27, 2008 | 11:47 AM
bigbadwolfe's Avatar
bigbadwolfe
motor swap
i have been without a cpu for to long i have been missing fte bad but i am back and with ?s i am about to pull my motor and put one in from a van with 130000 on it that i got for $600 good deal huh but anyways what if anything will i have to swap from my other motor
Old Jan 27, 2008 | 01:09 PM
tjbeggs's Avatar
tjbeggs
I know the oil coolers are different and maybe the motor mounts between the block and the frame. Also not sure if the accessories brackets (a/c, alt, ps) are the same but I think they are. BTW that is a good deal for a motor!! Nice find!
Old Jan 27, 2008 | 01:19 PM
MADVAN's Avatar
MADVAN
What year E motor.
All parts will swapout.
Just have to see if the fuel system is elect or mech.
You may not be able to go back to mech. (no casting in block)
Bill
Old Jan 27, 2008 | 04:18 PM
bigbadwolfe
the motor is out of a 97 i am hopeing it is mech i dont want to go get into all that right now maybe later i justwant my stroke back for right now the gasser is killing my wallet if you know what i mean
Old Jan 27, 2008 | 06:15 PM
mrblonde108's Avatar
mrblonde108
Hello
Hi Madvan it's me again dude didn't buy my bus. I'm kind of glad in a way. Will the harness from a e350 sd fit up to a f350? Are the powerstroke motor mounts the same as a 7.3 idi motor mount? I may put the engine in an older f350 also. It has 237kmiles title also said mileage is not accurate but it runs great. It only smokes on start up when it's cold. I'm going to get an oil analysis done. Before i pull the engine.
Old Jan 29, 2008 | 08:39 PM
bigbadwolfe
ok i just got the motor and it looks like the fuel pump has the black round ufo thing on it if i change the fuel pump and the injectors will i be ok another thing i just read another post that said something about the up pipes are not the same whats up with that i would like to know everything befor i start thanks
Old Jan 29, 2008 | 08:52 PM
MADVAN's Avatar
MADVAN
If the motor was from an F-series that is all you need to do.
Its a Cali (f-series) splitshot inj motor.
It still could be an E-series motor.
Does all the accessories look the same (location)
Bill
Old Jan 29, 2008 | 08:55 PM
bigbadwolfe
the motor is from a e350 what now
Old Jan 29, 2008 | 09:42 PM
bigbadwolfe
Help Please
Old Jan 30, 2008 | 05:02 AM
MADVAN's Avatar
MADVAN
PM sent
Also add the T-Stat hose connection (pipe) on water pump must be swapped.
Bill
dlaboone
Oct 1, 2016 09:43 PM
HKusp
21
Aug 24, 2015 05:38 PM
89_Bronco_lover
1978 - 1996 Big Bronco
May 6, 2015 04:14 PM
loggades
Oct 26, 2014 10:02 PM
1990-f250
Oct 29, 2013 09:45 AM
