1978 - 1996 Big Bronco
Engine Swap
Old May 2, 2015 | 08:38 AM
89_Bronco_lover's Avatar
89_Bronco_lover
Engine Swap
Ok so I have an 89 fsb and the motor crapped out on me, I have a donor motor in a 96 f-150 ready to go in, however I have a few questions. I know the firing order is different as are the plug ins for the distributor, what all am I going to need from the 96 to successfully make my 89 run with the 96 motor?
Old May 2, 2015 | 10:36 AM
Conanski's Avatar
Conanski
Rule #1 of engine swaps is... do not attempt to use any wiring the comes with the donor motor.
So for your swap that means remove the upper intake manifold and disconnect everything on the donor and remove it, and when you install the motor it will get the '89 engine wiring harness. There will be a sensor or two that won't have a wire to connect to but that is OK.
So differences between these motors include..
The distributor: '89 has a TFI module onboard while the '96 used a remote TFI. You will need to use the '89 distributor but before installing it in the '96 you must swap drive gears, the '89 motor had a cast iron flat tappet cam while the '96 has a steel roller cam and the distributor gears must match.
The EGR: The '96 uses a DPFE system while the '89 uses a position sensor. You need to use the '89 tube, valve and sensor so swap those to the '96 once it is installed.
IAC sensor: This is the intake air temp sensor, it's located in the lower intake on the '89 but in the airbox on the '96. Again you need to be compatible with the '89 system so you will have to swap lower intake portions.
When the motor is installed wire the spark plugs for the HO firing order.
Old May 2, 2015 | 04:20 PM
gatorfor88's Avatar
gatorfor88
You are the man Paul.
Old May 4, 2015 | 09:24 AM
Kemicalburns's Avatar
Kemicalburns
yup, Conanski nailed it
Old May 6, 2015 | 04:14 PM
89_Bronco_lover
Thanks for the info, I'll keep you updated on the progress
Skimp_nugget
Sep 13, 2018 07:45 PM
jk89cat
Mar 14, 2016 04:04 AM
Jamestat2
Sep 20, 2013 04:48 PM
revlimiter776
Jun 14, 2009 11:54 AM
tcb89
Feb 7, 2006 02:47 PM
