Grade 8 bolt question?
Old Jan 27, 2008 | 10:22 AM
Arnold Kenyon's Avatar
Arnold Kenyon
Are grade 8 bolts too hard to use for starter bolts? Will they ruin the threads in tha aluminum case of the transmission?
Old Jan 27, 2008 | 11:00 AM
brownfoot's Avatar
brownfoot
no
grade 8 is the same size as other bolts, so the threads will not be damaged
you can however damage things if the correct torque for the application is ignored
grading is not only the hardness, but mainly the tensile strength............you can drill holes in grade 8 bolts with standard HSS drills, for safety wire/cotter pins
Old Jan 27, 2008 | 11:13 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Arnold Kenyon
I've never really gave it much thought, but I have had trucks that seemed to
go though the cheap starters, and have to change three a week of the ones
they call life time! So I started putting " STUDs" in, and used good lock washers and new nuts anytime its pulled!
P.S. Sure makes a starter install go real fast, I really like this method.
Wally Womack
Old Jan 27, 2008 | 11:21 AM
Arnold Kenyon
The studs are a great idea. Do you remember what length you used?
Old Jan 28, 2008 | 09:30 AM
Pro-Street/StateTK
Arnold Kenyon
The studs I've used, I always just tried to match them up, In the Past I have
kept the studs less than 3 inch. They sure help hold the starter, while starting
the nuts! If you ever had to change the starter more that one a day they are
priceless,
Wally Womack
Old Jan 31, 2008 | 04:53 PM
tomcasino's Avatar
tomcasino
Just remember to use anti-seize on all bolts that thread into aluminum. After time the chemical reaction between the two different metals will gall the threads. I learned the hard way. I used a distributor hold down bolt in an aluminum manifold without anti-seize. After time I was able to pull the bolt straight out without turning it. The aluminum threads were stuck to the steel bolt.
Old Jan 31, 2008 | 06:25 PM
Arnold Kenyon
That may be what happened to the threads in the transmission. The threads pulled out and I had not tightened the bolt up enough to justify that. I guess it is time for the heli coil.
Old Jan 31, 2008 | 06:52 PM
tomcasino's Avatar
tomcasino
I couldn't even use a heli-coil. One day I bumped my distributor and it moved. I turned the bolt but it wouldn't tighten. When I pulled it out, it looked like someone had drilled a hole. No threads. I had to tap to the next size. What a PITA pulling the intake just to tap one hole. I use anti-seize from now on.
Old Jan 31, 2008 | 06:55 PM
greythorn3's Avatar
greythorn3
you could have jbwelded a larger stud into the intake tell you had to rebuild or change intake gasket right?
Ray
