jacked up idle
Old Jan 27, 2008 | 08:03 AM
kenaijoe's Avatar
kenaijoe
jacked up idle
<hr style="color: rgb(102, 102, 102);" size="1"> Morning....91 F150 6 cyl. fuel injected. When I start the truck I get major high erractic idle. Doesn't matter if the truck is warmed up or not. Showing no codes. Replaced IPS...plugs...wires...rotor/cap. No change. Noticed the plugs showed the engine running lean. No vac leaks that I can find. Any ideas would be greatly appreciated...peace
Old Jan 27, 2008 | 12:59 PM
wde3477's Avatar
wde3477
Have you inspected your Idle Air Control (IAC) solenoid?
Old Jan 28, 2008 | 07:23 AM
kenaijoe's Avatar
kenaijoe
more parts
Hi: replaced IAC, TPS and get no change in the idle. Truck runs better with the tune up but still has high erratic idle speeds...sign me...still jacked up...thanks for your help
Old Jan 28, 2008 | 09:44 AM
tfowler306's Avatar
tfowler306
Your swap parts list tells me that there is a vacuume leake some where. If it is a high eratic idle in the rang of 1800 to 2500 RPM check the break booster gromet and that end of the vac line.
Rocketattack
Jul 11, 2010 10:49 AM
Beast01
Arizona Chapter
Sep 12, 2007 08:32 AM
cumberlandboy
Aug 18, 2007 06:17 AM
1957F100
Jul 11, 2007 10:47 PM
