Engine swap to a V8
Old Jan 26, 2008 | 10:59 PM
VandeBogart's Avatar
VandeBogart
Engine swap to a V8
Has anyone ever swapped in a v8 into their ranger? Like a 4.6 or 5.0? I don't plan on doing this but was just wondering if it's possible.
Old Jan 26, 2008 | 11:01 PM
monsterbaby's Avatar
monsterbaby
Not only has it been done, it's been done so much in the case of the 5.0 that you can actually buy kits to do it.
Old Jan 26, 2008 | 11:27 PM
projectnitemare's Avatar
projectnitemare
Either can be done with the time and money. What year of truck, EFI or carb, street legal? There are a lot of questions and options to go with. All depends on your skills and the amount of money you want to spend.
Matt
Old Jan 27, 2008 | 02:52 AM
Level2's Avatar
Level2
5.0L is much easier. The 4.6 is much wider and would require extensive modification to fit. One member on here has done it and did a very nice job of it. He used a 4.6L DOHC from a lincoln Mark VIII.
Old Jan 27, 2008 | 07:53 AM
projectnitemare
Nah the DOHC is way tight, that was a SOHC 4.6 in a 98 2wd Ranger. There is a guy hanging around TRS putting a SOHC into a Gen I Ranger. The 302 is much easier and there is much more support and aftermarket. If you have the time, space and skills pretty much anything can be done.
Matt
Old Jan 27, 2008 | 01:07 PM
RangerPilot's Avatar
RangerPilot
I've done the 302 swap. Not too difficult at all, or time consuming for that matter.
4.6 SOHC swaps aren't too terribly hard. A 4.6 DOHC would be powerful, but difficult no doubt.
Or you can be like monsterbaby...when the 302 just won't cut it, put an F-150 frame under it and drop the biggest engine you can find in.
Old Jan 27, 2008 | 01:56 PM
monsterbaby
Zach that 528 is NOT the biggest engine I could find thats why I am currently building a 572, and if things go well it will be a Boss headed (hemi) 572 making 4 digit hp numbers NA.
Old Jan 27, 2008 | 04:41 PM
RangerPilot
I think the word I'm looking for is "scaryfast".
Old Jan 27, 2008 | 06:04 PM
Level2's Avatar
Level2
Originally Posted by projectnitemare
Nah the DOHC is way tight, that was a SOHC 4.6 in a 98 2wd Ranger. Matt
You are half right. It is a 2wd 98 ranger but it isn't a SOHC, its a DOHC from a lincoln mark VIII. members name is Greg R. Look it up.
Old Jan 27, 2008 | 06:11 PM
RangerPilot
Greg only spent $112 total on the swap (he pawned off some stuff, and had a lot of it in his possession already) according to his site.
http://281ranger.homestead.com/
Here's a picture, I hope he doesn't mind me linking it, just to give you an idea of how beastly the 4.6L DOHC is in the Ranger:
Old Jan 27, 2008 | 06:28 PM
monsterbaby
physically the saying is if a DOHC came out of the engine bay a 429/460 will fit in place of it even with Boss 9 heads if that gives you an idea. That little engine is as wide and tall as a big block.
Old Jan 27, 2008 | 07:55 PM
VandeBogart
Thanks for all of the input everyone. I think i'd definitely swap in a 302 if i had the chance
Old Jan 27, 2008 | 10:37 PM
RangerPilot
If I can be honest with you, going with a stock 302 isn't going to impress you after a short bit. 302s aren't powerhouses by any means. Since physically the 351 shares block sizes, I would suggest that, as minimally more mods are required.
I went with a mildly hopped up 302, so I was satisfied (until I wanted more power lol), but stock, just to give you an example, I have a '98 Explorer. In '98, the 4.0L SOHC (which I have) put out 205 horsepower. The 5.0L/302 V8 put out 210 horsepower. The 4.0L SOHC actually 0-60's and quarter miles faster than the 302. Pretty sad, huh? The 302's old school technology in a new school world.
Old Jan 28, 2008 | 12:50 AM
Level2's Avatar
Level2
The only problem with putting a 351 windsor in is that the engine is taller and wider than a 302 since the deck height isn't the same. The intake on a 351 is 1.5" wider than on a 302 because of the taller deck. In all the 351 is about 3 inches taller. That means different headers as well since the exhaust ports sit higher.
A 351 is 21" wide where a DOHC 4.6 is 30" wide!!!! A 460 BB is only 26 inches wide but 4 inches longer than a 4.6.
If I had the money to do the swap I would probably go with a FRPP Z head crate engine with 390HP and 360 TQ or do something like a 331 stroker with a mild turbo.
Old Jan 28, 2008 | 07:34 AM
Pablo-UA's Avatar
Pablo-UA
Yes, 5.0V8 with tranny from Explorer 5.0V8. Saw this truck in Moscow.
