e4od \c6 gear ratios
Old Jan 26, 2008 | 05:42 PM
mike86f350's Avatar
mike86f350
does anyone know the gear ratios for both the c6 and e4od diesel trans thanks mike
Old Jan 26, 2008 | 06:11 PM
Dave Sponaugle's Avatar
Dave Sponaugle
C 6
1st - 2.46
2nd - 1.46
3rd - 1
E4OD
1st - 2.71
2nd - 1.54
3rd - 1
OD - .71
Old Jan 26, 2008 | 11:29 PM
mike86f350's Avatar
mike86f350
thanks dave
Old Jan 26, 2008 | 11:44 PM
turboman24's Avatar
turboman24
Hey DAve does the 2.46:1 and 1.46:1 and 1:1 is that the ratio of engine revolutions to wheel revolutions considering one has stock tires and a 4:10 rearend
Adam
Old Jan 27, 2008 | 01:37 AM
Dave Sponaugle
That is the ratio of the crankshaft RPM to the drive shaft RPM.
The axle ratio divides the drive shaft RPM by the axle ratio to determine the axle RPM.
Engine RPM 2000
2.46 first gear
Driveshaft RPM 813
Axle ratio 4.10
Axle RPM 198.29
235/85-16 tires 31.72" diameter
31.72*3.1415=99.648" travel per revolution of the tire
99.648/12=8.304 feet per revolution
5280/8.304=635.838 revolutions of the tire per mile
198.29/635.838=.311
60*.311=18.66 MPH at 2000 RPM in first gear if there was no loss in the torque converter and I did not round off the numbers in my calculations.
kobidoo
Feb 17, 2016 04:58 PM
Mike E.
Sep 27, 2011 08:14 PM
compressorguy
Jan 2, 2009 12:43 PM
harddrive4x4
Bronco II
Oct 28, 2003 07:11 AM
ExcellentRed
Jul 5, 2003 05:22 PM
