manual choke?
Old Jan 26, 2008 | 05:25 PM
antunez13's Avatar
antunez13
manual choke?
Ive been having problems with the carb in the cold, probally the choke because once it warms up it runs good, it runs at about 750 rpm in idle in park and in drive about 650 but when its cold and coming to a stop it will shut off.
would putting a manual choke be better than guessing with an automatic?
What is a good idle rpm
park rpm?
drive rpm?
1986 inline 6 1bbl carb
Old Jan 27, 2008 | 06:07 PM
antunez13's Avatar
antunez13
well i went for guesse it couldnt hert starts up perfect and can adjust i think its better than geusing at were the spring would be, and i adjusted the carb to be hundred rpms more than at firstso like 850 at park,and 750 at drive we will se how it does tomorrow in the cold,
I also cut off both cats sounds mean i love it there was a metal tube with flexible hose going to the pipe after the 1st cat didnt know what it wasi said screw and cut it.
Old Jan 27, 2008 | 08:05 PM
85e150's Avatar
85e150
You have a feedback carb. The metal tube you cut, where did it go? Could it have been a heat tube for the choke?
Old Jan 28, 2008 | 12:44 AM
Rogue_Wulff's Avatar
Rogue_Wulff
This sounds like an air tube for feeding fresh air from the air pump, into the system, to help the main cat burn off the pollutants.
If you still have the cat(s) in place, that tube is kinda important. The cat won't live as long without the fresh air being supplied to it. At least, that's the theory.
On the other hand, I had a cat on my truck for more than 10 years/100K miles, and the air pump never had a belt on it. The port for the air pump check valve was also plugged with a pipe plug. The cat never clogged, but it did start to rust the ends off, so I took it off a couple weeks ago, when I had a new exhaust system put under it.
Old Jan 31, 2008 | 06:10 PM
antunez13's Avatar
antunez13
theres no cats or muffler on it just the manifold.
Old Jan 31, 2008 | 11:25 PM
rikard's Avatar
rikard
Do you mean that you don't have any exhaust after the manifolds? These engines need a little back pressure to idle correctly. You don't need the cat or muffler but you should have some pipes 2.25 or 2.5 going back to at least the rear of the cab to idle below 1000 RPM.
regards
rikard
Old Jan 31, 2008 | 11:41 PM
TallPaul's Avatar
TallPaul
When the auto choke in my '77 F100 300 I6 went out, I installed a universal manual choke kit. Was fun at the time.
Old Feb 1, 2008 | 03:16 PM
antunez13's Avatar
antunez13
regards
rikard
its in the shop right now to tune the carb and flomaster exhaust
jbonilla77
Jul 29, 2016 11:29 PM
yabadaba
May 15, 2016 10:29 AM
okie72
Jan 29, 2014 09:32 PM
granny_rocket
Dec 23, 2012 08:15 PM
GQROD
Jan 1, 2010 03:36 PM
