Used engine
Old Jan 25, 2008 | 04:13 PM
Corner Gas's Avatar
Corner Gas
Used engine
I am looking for a used engine for my truck (300I6) and I was wondering what the compression should be.
Old Feb 1, 2008 | 06:14 PM
Corner Gas's Avatar
Corner Gas
I found a used engine the other day and the comp is 135 - 150 and the oil psi is 15 - 40. My question is if these numbers sound good.
Old Feb 1, 2008 | 06:19 PM
85e150's Avatar
85e150
Numbers sound ok, are all the holes about the same or some 135 some 150?
Old Feb 1, 2008 | 07:42 PM
fmc400's Avatar
fmc400
MSEE
Those numbers sound good. As long as no cylinder is more than 10% above or below any other cylinder, you're in good shape. That oil pressure sounds all right too; rule of thumb is 10 pounds for every 1000 rpms.
Old Feb 1, 2008 | 07:51 PM
Corner Gas's Avatar
Corner Gas
Thanks for the replys, I just wanted to make sure before I went out and bought it.
Quentin10
May 27, 2014 03:04 PM
tseng19
2004 - 2008 F150
Mar 27, 2012 07:33 AM
arobe06
Apr 27, 2010 10:34 AM
big-B
Computer Chips & Tuners
Aug 29, 2006 05:28 PM
ClatonK
Oct 16, 2005 06:47 PM
