Holley electric choke question
Old Jan 29, 2014 | 08:05 PM
okie72's Avatar
okie72
I have a Motorcraft 4160 that is made by Holley it is 600cfm. It had a hot air choke I replaced it with a electric choke. The choke sets good but will not kick off of the last setting on the fast idle cam. I can push the fast idle cam down with my finger so it will idle at a normal 650rpm but if I push the throttle it will reset the fast idle cam on the lowest setting again. I can get it to drop off of the fast idle cam but I have to turn the choke cap clockwise about 1 inch past the idex marks which makes it hard to start when cold.
Old Jan 29, 2014 | 08:23 PM
hotstuff's Avatar
hotstuff
on the fast idle cam there is a screw you can back off or a tang you bend to get the right step down , for the correct cold idle
Old Jan 29, 2014 | 09:05 PM
okie72's Avatar
okie72
I did adjust the fast idle screw all the way out and had no luck should I bend it back a little?
Old Jan 29, 2014 | 09:32 PM
Charlie5280's Avatar
Charlie5280
Yes, bend it back just a bit
swampthang
Apr 9, 2020 12:29 PM
yabadaba
May 15, 2016 10:29 AM
f100help
Oct 9, 2010 03:37 PM
fmc400
May 1, 2004 12:00 AM
